As of today I have finished the second test enclosure (closed) for the Fane 12-250TC.
Compared to the other one which I ran for a few weeks (mono) it has less details and highs which is expected.
I don`t like to wait.
How can I break-in the new one FAST.
20Hz sine and hope it won`t get too hot?
Techno for continuous punches?
Classic?
The speaker is already in the enclosure if it matters.
Classic?
driver brake-in
Hi there g: Have patience, its worth it to get the best results from your new driver. I am breaking in another Seas ER18n-TRD 7" extended range driver and it is at 58 hours on classical music. The first 48 hours were at 48db 1meter. Have now increased level to 53db. I'm now using a cardboard box experimental TL and listening. At 135 hours on the first one I increased the level to 60 db untill 235 hours. The general feeling is that the spider (usually doped linen) will dvelope micro cracks, and the surround will flex out during the break-in process. Large displacements at normal listening levels may alter this micro cracking...hence low Hz sine waves are deemed to be detrimental. regards, Michael
As of today I have finished the second test enclosure (closed) for the Fane 12-250TC....I don`t like to wait....
How can I break-in the new one FAST...
...Classics? The speaker is already in the enclosure if it matters.
relationship of break-in box size to driver vas?
Hi there: How does box size effect driver break-in? I used a 2.2cf TL to break-in a Seas er18-trw extended range driver, with a vas of 38L. Box is cardboard, so sealing is not perfect. ...regards, Michael
It takes real world use to properly break them in. Be patient.
How big of an enclosure did you build? ...dave
OK.
Around 42 ltrs.
1.48 ft³
When i did a sim for another thread i suggested a minimum of 100 litre, 50 litre in a pinch. Are you using them by themselves?
dave
Holes to alter Q?
But will I loose spl?
Since now I used this on the walls, material thickness 5mm, air-permeable:
And this inside, realtively dense:
Behind the speaker I got something like this:
22mm sanded OSB3.
Sounds very good.
Bass is precise and has a nice punch.
22mm sanded OSB3.
Sounds very good.
Some FR voice coils are made of paper for sheer musical results hence the low power rating, think about it when you are in a long session of hardcore metal ''music''.I don`t like to wait.
Classic?
Thanks for the advice. But...
this one (Fane Sovereign 12-250TC) has a glass fibre voice coil which is more robust.
Also the 250w rms rating helps with surviving( of the driver, not of the hearing ).
Oh a relief to know. For stuffing consider this tips:
How Treat Passively Peaky Fullrange Drivers
- Full Range
- Fullrange break-in
