Recommend driver for 1.16 ft^3 box
Old 6th December 2017, 08:46 PM   #41
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by vdi_nenna View Post
So then which Mark Audio driver? Any 6.5 inch?
If you want to stick with paper the 5.25 A10p. It goes lower, higher and edges the larger driver in midrange, and is almost as efficient. More versatile as to box size (the A12p seems to really want a big box) and cheaper to boot. The 6.5 A12p edges it out only in how much air the larger cone can move.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th December 2017, 01:45 PM   #42
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Recommend driver for 1.16 ft^3 box Send a message via Yahoo to vdi_nenna
This TB seems to do just about everything I need. It's on sale and I have $10 off too.
If what's on the spec sheet is true... With that in mind, I will check out the A10p as well.
Tang Band W6-2144 6-1/2" Paper Cone Full Range Driver 8 Ohm
I build, therefore I am.
Old 11th December 2017, 03:07 PM   #43
vdi_nenna's Avatar
Fostex are sometimes up around 18%. TBs even greater (althou many less samples).
Matching Tang-Band drivers could be a problem, but I do have a WT3 woofer tester. I can see just how different they are. At $65 each, ordering 4 would be ok. Maybe I could get closer matched pair out of 4 drivers.
thanks,
Vince
Old 11th December 2017, 08:47 PM   #44
frugal-phile(tm)
planet10's Avatar
When i get an order for FE206 or FE166 or other custom orders i usually buy 4 which does give better chances of getting a match.
dave
Old 14th December 2017, 07:21 PM   #45
chrisb is offline chrisb
Regarding the "Castle" microtower that Dave mention a few posts back, I've built at least 3 versions - the first as seen in his posted photo with CSS EL70 (now residing in my mom's living room), and two with top panel angled forward at 10dg. I also built a single pair of the "true" bipole, but much prefer the placement flexibility and spaciousness of the Castles.
With appropriate dimensions and vent tuning, this topology should work with a wide range of drivers, either full-range or simple 2-way combos. I've thought about an upscaled version with either A7.3, or A10P and A5.2 as tweeter.
like my mind, this space intentionally blank
Old 14th December 2017, 07:35 PM   #46
frugal-phile(tm)
planet10's Avatar
Those got given away in the end, the castle configuration, particularly if not pulled way out into the room, is generally preferred.
dave
Old 21st December 2017, 12:36 AM   #47
vdi_nenna's Avatar
Received 4 TB 6.5" FR drivers today. They are so heavy I thought they sent 8.
These should go together pretty quick.
Thanks for all the advise.
Vince
Recommend driver for 1.16 ft^3 boxHide this!Advertise here!
Recommend me a Full range driver dnic77 Full Range 27 8th August 2015 07:16 PM
Recommend a 8" Subwoofer driver dannyjmf Subwoofers 30 13th August 2011 12:53 AM
Please recommend Subwoofer Driver mart34 Subwoofers 5 25th September 2008 11:07 PM
recommend me a driver Shpoop Full Range 13 27th January 2008 07:33 PM
Bass Driver Recommend PTSOUNDLAB Multi-Way 2 10th June 2002 06:53 AM
