Pair of CHR70.3's Just Ordered!
Old 5th December 2017, 01:30 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Use skinny wire… we use a pair of 24g solid wires pulled from a CAT5 cable.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th December 2017, 07:31 AM   #22
paul burchell is offline paul burchell  Canada
paul burchell's Avatar
I do it with a rasp and a chisel and its not crude at all, as a matter of fact it does not leave the sharp edge transition of a chamfering bit rather a smooth rounded surface.
Paul Burchell Fine Woodworking
Old 5th December 2017, 07:34 AM   #23
frugal-phile(tm)
planet10's Avatar
Paul. you are a pro… i am a hack
dave
Old 5th December 2017, 08:02 AM   #24
Thanks Dave ive been called a lot of things but never a pro, I think im starting to blush. No wait i think thats the wind chill
Old 5th December 2017, 11:11 AM   #25
coopman is offline coopman  United States
I'll probably use a rasp drill bit of some sort. There isn't a lot of room for error along the edge of the cutouts near the sides of the cabinets.
Old 5th December 2017, 12:26 PM   #26
IG81 is offline IG81  Canada
IG81's Avatar
Originally Posted by coopman View Post
One more concern: the soldering of the wires to the speaker terminals. What's the best way to do that without melting the plastic pieces connected to the metal tab?
Skinny wire as mentioned by P10 will sink less heat away from the soldering site. Clean the tabs, use a good solder with flux core, a hot iron with a large enough tip (0.125" is OK) and be quick, but don't rush.
Old 5th December 2017, 04:18 PM   #27
chrisb is online now chrisb
The #24 solid takes very little time to heat up & solder - just be careful not to nick the wire with strippers, and gently fold back through the hole in terminal. I don't get so carried away as to wrap it more than a single fold.
like my mind, this space intentionally blank
Old 5th December 2017, 06:56 PM   #28
frugal-phile(tm)
planet10's Avatar
If you are good you can get away with no fold at all. I’m not always that good all the time, sometimes a single fold and a squessze is nice to hold it in place so you don’t need that “3rd” hand.
Enuff CAT5 can often be had for free by asking at the local computer store for scraps.
dave
Old 7th December 2017, 12:26 AM   #29
I received the drivers this afternoon and have begun the painstaking process of breaking them in at a barely audible volume level.
Pair of CHR70.3's Just Ordered!Hide this!Advertise here!
CHR70 ShoeBox-70.3 Spec Full Range 57 19th May 2016 01:03 AM
CHR70 vs. A7 intermantas Full Range 45 26th June 2014 07:32 PM
K.I.S.S - CHR70 Project thunk303 Full Range 10 22nd June 2012 02:16 PM
[UK] pair CHR70 2010 gold + salad bowls jimbo1968 Swap Meet 4 13th July 2010 10:24 AM
