Horn Drivers
Horn Drivers
Old 7th December 2017, 12:20 PM   #41
IG81 is offline IG81  Canada
IG81's Avatar
Originally Posted by David McBean View Post
Example of an eight-sided tractrix horn. The side panel dimensions are given in the attached exported Tractrix.txt horn data file.
See the 'Export Horn Data' section in the Hornresp Help file for further details.
I didn't keep up with the latest features in HR, looks like this is exactly what I used Tractrix12.exe for, thanks for posting this!
Old 7th December 2017, 07:49 PM   #42
GM is offline GM  United States
GM's Avatar
Originally Posted by IG81 View Post
I scoured the web for about 20min looking for it, but looks like you out-Googled me. Thanks, it's a neat little program that I may yet use again.
You're welcome! Popped up first thing and immediately auto downloaded, so first thought was it's malware and hoped AVAST had dealt with it. For whatever reason, I've typically been able to find stuff either quickly and/or what others couldn't. Long time ago, me, Cal [moderator] and some others did an impromptu test where we all searched a number of same things and while I typically zero'd right to it, the others got totally different [often irrelevant] first page results.
Apparently, our personal search patterns dominates over what we're looking for, so guess I've done way more audio related searches than you since it's been a regular thing for me since Christmas '96.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th December 2017, 07:57 PM   #43
GM's Avatar
Thanks! I'm now years behind in keeping up with your enhancements! So much for all those 'Never going to happen' requests.
GM
Old 7th December 2017, 09:57 PM   #44
mkane77g is offline mkane77g  United States
Always Learning
Horn Drivers
Wow. Some fantastic links and I've got some guidance and some work to do.
Old 7th December 2017, 10:21 PM   #45
Always Learning
Horn Drivers
All this figuring out how to use these calculators making my head spin.
Old 8th December 2017, 06:39 AM   #46
David McBean is offline David McBean  Australia
Just be aware that Tractrix12.exe contains an error.
The 'x proj' value gives the length along the curved wall of a circular cross-section horn. It should give the length along the curved petal side wall.
www.hornresp.net
Old 8th December 2017, 06:48 AM   #47
Hi GM,
Years indeed! The multiple petal option was added in April 2011 :-).
Hornresp
Kind regards,
David
www.hornresp.net
Old 8th December 2017, 12:38 PM   #48
IG81's Avatar
I caught that in the above linked thread. I'm guessing the error is worse the lower the number of petals.
Old 8th December 2017, 05:48 PM   #49
GM's Avatar
Hi GM,
Hornresp
Kind regards,
David
Greets!
Interesting! If I ever noticed, it's long forgotten and probably any other HR enhancement I'll likely never use, especially any that makes for intense woodworking.
GM
Old 8th December 2017, 06:35 PM   #50
Hearinspace is offline Hearinspace  Canada
Horn Drivers
Maybe this isn't the perfect place for this question, but it isn't big enough to deserve a dedicated thread and it does relate to OP mkane77g's interest in the conical and joshcpct's pointing out its poor low frequency loading weakness.
Looking at the popular and commercially successful Synergy horn, is it a mistake to see it as a conical with added LF drivers to overcome that weakness?
Horn DriversHide this!Advertise here!
FS: JBL Horns + Drivers M2 Horn + Flange D2430K Drivers hum4god Swap Meet 3 23rd November 2016 10:37 PM
T/S parameters for horn drivers buggsson Multi-Way 7 25th March 2008 08:53 AM
Horn sub. wich drivers?? wuffer Subwoofers 4 28th July 2007 03:01 PM
Dual Drivers and Horn Humanjava Full Range 1 16th March 2007 02:38 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
