Horn Drivers
Horn Drivers
Old 5th December 2017, 05:44 AM   #11
Hearinspace is online now Hearinspace  Canada
Horn Drivers
The smaller of the two wooden conicals uses a Cogent driver made by Steve Schell and Rich Drysdale but no longer produced.
As mentioned above it depends on the range you're after though I remember that Bill Woods, designer of the horns , used to say he liked the B&C DCM50 which was inspired by the old RCA MI-1428 - the improved development of which resulted in the Cogent DS-1428.
Old 5th December 2017, 11:31 AM   #12
mkane77g is offline mkane77g  United States
Always Learning
Horn Drivers
Thanks folks and for the link.
Old 5th December 2017, 11:53 AM   #13
Always Learning
Horn Drivers
Starting here because it's inexpensive. https://www.parts-express.com/pedocs...ions-44863.pdf
Old 5th December 2017, 12:23 PM   #14
Joshcpct is offline Joshcpct  Germany
the OMA are gorgeous! Modern, industrial, artistic. Wonderful.
But conical horns, nogo. Lo efficiency, limited bandwidth, no CSD, strong beaming, HW-notches.... the worst of all.
But I totally understand one might gives optics a higher priority. I often do
Old 5th December 2017, 02:22 PM   #15
Always Learning
Horn Drivers
So your saying they look good but performance sucks? If that's the case I may as well stay with OB.
Old 5th December 2017, 02:35 PM   #16
IG81 is offline IG81  Canada
IG81's Avatar
efficiency: with a capable compression driver, still enough to match any but the most dedicated HE bass schemes
bandwidth: no worse than most horns, needs EQ because of constant directivity of course
beaming: ??? they display constant directivity dictated by the angle, Exp or Tractrix beams more. Driver or throat diameter will dictate when the conical horn actually starts to beam
Not saying they are perfect, no audio device is, but they certainly are plenty usable.
Old 5th December 2017, 08:16 PM   #17
Always Learning
Horn Drivers
I need another project so I'm going for it.
Old 6th December 2017, 01:44 AM   #18
Horn Drivers
Good stuff.
I'm eager to see how you decide to mount the drivers. It's always been something with DIY conicals of wood that I haven't found a satisfactory answer to. I figure the the small drivers you are starting with might be easy enough to strap against the throat with bands attached farther up the length of the outside of the horn. But trying heavier bodied drivers like the old Altecs ,JBLs, etc., would be harder to make stable that way.
Bill Woods' answer was to terminate the throat end of the wooden horn in an aluminum casting, machined round at the last 1/4" and use a 1/4" thick mounting plate "donut" with edgewise set screws to hold it on to the machined casting once the drivers had been bolted to it. Doing the whole thing purely of wood though, that would be another story. Please let us know how it goes.
Old 6th December 2017, 01:46 AM   #19
Pano is offline Pano  United States
Pano's Avatar
Horn Drivers
Why is this in Full-Range?
Old 6th December 2017, 02:20 AM   #20
croweproductions is offline croweproductions  Canada
Oswald Mill is not conical even though it looks that way. Each leaf is curved inside to form a flare.
Horn DriversHide this!Advertise here!
FS: JBL Horns + Drivers M2 Horn + Flange D2430K Drivers hum4god Swap Meet 3 23rd November 2016 10:37 PM
T/S parameters for horn drivers buggsson Multi-Way 7 25th March 2008 08:53 AM
Horn sub. wich drivers?? wuffer Subwoofers 4 28th July 2007 03:01 PM
Dual Drivers and Horn Humanjava Full Range 1 16th March 2007 02:38 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
