My New Line Array--It's a Modified CBT24
Old 13th October 2017, 08:46 AM   #11
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Can't wait to see the rest of this journey. What kind of EQ is planned?
Hopefully some FIR experiments along the way?
Use Science to design your speakers and they will sound like a piece of Art...
Old 26th November 2017, 12:14 PM   #12
Dr1v3n is offline Dr1v3n  United States
Any progress Jim?
Old 26th November 2017, 08:12 PM   #13
Jim Griffin is offline Jim Griffin  United States
Enclosures are in for painting and sub woofers boxes are in work as well. All this is slower than I wanted. I have the internal wiring (3 strings per side for each of the 3 banks) ready for insertion when the boxes are finished.
Thanks for asking.
Old 27th November 2017, 02:35 PM   #14
HankF is offline HankF  United States
Progress is progress. I'm in the process of ordering a couple of Rythmik F12G subs.
Old 15th December 2017, 11:12 AM   #15
Almost two weeks ago my CBT24 cabinets completed their six weeks visit to the auto body shop for painting. The results are exceptional! The Nebla Gray Pearl paint looks terrific. While dark gray in low lighting, they have highlights when in a brightly lit room or under a spotlight.
I completed the assembly and the wiring process over the last several days. I had pre-built the 3 wiring harnesses for each speaker (each speaker has 3 shading or weighting banks) with 6 different wire colors. The harnesses eased the process plus polarized connector clips and labels helped to prevent any mistakes.
My first listen to the arrays was two days ago. I’m listening in my living room which is 23 feet wide by 32 feet long with a ceiling height that extends to an apex of 18 feet across the center of the room. A Marantz 1602 (50 watts at 8 ohms) receiver currently powers the arrays. Though the arrays have a 4 ohms nominal impedance, this light weight receiver seems to be able to do the job for now. Two 10 inch subs are positioned beside the equipment cabinet which is centered between the CBTs. The sub crossover to the CBTs at 120 Hz while the CBTs have their F3 point near 130 Hz. No equalization for my initial listening.
CBTs have the characteristics preached by Don Keele in his many CBT papers which detail the theory behind their constant beamwidth and constant directivity behavior. They feature near constant coverage cross the sound stage and near constant volume level from front to back within the room. Keele states that a CBT is essentially time aligned and linear phase. A CBT array forms a virtual point source with extremely uniform broadband directional coverage of the CBT.
My first observations are that my CBTs have a real ‘jump’ factor with an easy musical pace. I hear sounds that we didn’t hear during earlier listening sessions with different speakers on these same recordings. I can sit on axis to one array and clearly hear sounds emitted by the other array so their imaging is impressive across the sound stage! Uniformity of the radiation sound from front to back and side to side is there in spades.
I'll have lots of photos and I will post them later.
Jim
Old 15th December 2017, 11:27 AM   #16
Omholt is offline Omholt  Norway
Omholt's Avatar
Looking forward to pictures Jim :-)
Sounds like you have a great room, spacious.
Bjorn
www.lydogakustikk.no
Old 15th December 2017, 11:54 AM   #17
dziemian is offline dziemian  Poland
I am eager to see the photos too.
Old 15th December 2017, 10:16 PM   #18
Try this link to a Modified CBT24 Gallery:
Modified CBT24 - Google Photos
Old 15th December 2017, 11:33 PM   #19
They look great Jim! I imagine you still have to listen at lower levels to break in the drivers? I don't think 50 watts is going to cut it at louder levels.
Old 16th December 2017, 09:02 AM   #20
wesayso's Avatar
I'd think the 50 watt will be more than enough as the bottom end is supported by subs.
My New Line Array--It's a Modified CBT24Hide this!Advertise here!
CBT24 line array speakers jayce996 Multi-Way 81 24th August 2017 09:39 PM
30 Driver CBT Line array 30 Fountek FE87 driversper array T85matt Planars & Exotics 3 26th December 2016 07:51 PM
Short Line Array (line source) build perceval Full Range 226 4th January 2015 03:08 PM
Help with converting sealed box line array loudspeaker to transmission line enclosure jb0194 Multi-Way 3 7th January 2012 06:08 AM
t-line subs for a DIY line array tom1356 Multi-Way 17 28th December 2002 01:15 AM
