What do you guys/gals think of PVC for FR enclosure?
Old 5th October 2017, 10:48 PM   #21
Dr1v3n is offline Dr1v3n  United States
It's very nice the endcaps are rounded internally and externally. It's also nice that the PVC is thicker on the front where the driver is as opposed the thickness where the pipe comes in: 8.5mm vs. ~6.8mm. The P7 flange thickness is only about 3mm which leaves a 5.5mm mounting surface, plenty sturdy. Perfect and flush mounted too, more on that later...
I've also researched how to stain PVC vs painting which can flake. More on that too when the parts come in, but it involves methyl ethyl ketone and petroleum dye mix in order to penetrate the PVC without affecting dimensions.
Cheers
Old 6th October 2017, 04:27 PM   #22
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
Rather than messing w/ methyl ethyl ketone (AKA: MEK), I would find some paint intended for plastics. MEK is wicked, nasty stuff. IIRC, there were folks in the printing industry who suffered permanet neurological damage from that stuff!
Just the opinion of a retired analytical chemist.
Cheers, Jim
A day without music is like a day without food.
Old 6th October 2017, 11:17 PM   #23
Cheers, Jim
I read the wiki on Butanone/MEK. I don't want to endanger myself or my family with the lingering fumes after painting the tubes and endcaps with this stuff. So, I'm abandoning this process. I'll find another way to color coordinate the enclosures with the drivers.
Thanks very much for your post Jim!
Old 7th October 2017, 12:10 AM   #24
suprf1y is offline suprf1y  Canada
I used both Krylon fusion primer (withautomotive paint) and paint intended for plastics on the fenders of my vintage MX bike and they didn't crack, chip or separate in several years of racing and washing with a pressure washer, so it can be done. Prep is the key.
Old 10th October 2017, 02:53 PM   #25
Ok, I finally got the tubes in. Jeezus what a mess. Only got 13 out of 28...
Old 10th October 2017, 02:57 PM   #26
All parts here for 4 experimental units. Now how to tell if the holes for the drivers have been drilled 'true' center. I'll mount the drivers and literally just roll the endcaps and observe.
Old 10th October 2017, 03:17 PM   #27
My babies mounted. They roll true. The 'manufacturing' process is established. Now to see if they will perform better than a rectangular box setup!
Old 11th October 2017, 06:07 PM   #28
Got 2 of the new ones wired up . I'll be listening to them for the next couple weeks to break them in.
I should've gotten 9" long tubes because both endcaps add about 3 inches to overall volume. Also, these 5" PVC tubes actually measure 5 3/8" ID (136.5mm) 5 9/16" OD (141.3mm) for .2cuft or 5.7litres.
With no stuffing/felt or internal damping they sound very good at low volumes... Will have to wait to try louder volumes. Compared to my arrays, they sound less 'boomy' buts it's not a fair comparison yet as these aren't broken in.
I'm currently wiring up the other 2 and trying to figure out a temporary and long term mounting solutions.
Cheers
Old 11th October 2017, 06:19 PM   #29
Here's a size comparison. The good news is they both feel very similar in weight.
Old 1st November 2017, 10:03 PM   #30
Gears churning for 24 PVC enclosures, including newer more eye appealing attachment fixtures. No wasted PVC, except the dust.
Shortened the enclosure to about .11cuft.
What do you guys/gals think of PVC for FR enclosure?Hide this!Advertise here!
Hi Guys, just bought a JBL 1214 GTO ,need help to built a nice ported enclosure kevin22 Subwoofers 3 15th October 2015 02:39 PM
You guys and gals recognize any of this equipment? Sodacose Tubes / Valves 12 7th June 2015 10:25 PM
What do you guys (gals) think of this? aptquark Planars & Exotics 8 15th June 2010 02:41 AM
Hi Pals & Gals messenger Introductions 2 8th June 2010 01:18 AM
All you horn guys and gals Variac Multi-Way 6 17th June 2003 08:27 PM
