What do you guys/gals think of PVC for FR enclosure?
Old 16th November 2017, 11:21 PM   #91
perceval is offline perceval  Taiwan
perceval's Avatar
Convolution and an app, like JRiver or Foobar.
One amp, or bi-amping if preferred.
Old 16th November 2017, 11:45 PM   #92
Dr1v3n is offline Dr1v3n  United States
Since these drivers can only take 20W, I Have Been looking into driving each of these P7's with a 50-100W class D amp with bluetooth. They're about $25US each and I can mount them on the monoliths.
I've heard old school class D amps and they were harsh. Willing to experiment with new school..
Old 17th November 2017, 03:48 PM   #93
Think is offline Think  Netherlands
Are the drivers broken in before you mounted them? Otherwise the sound will probably become better in next few months of listening.
I listened to the scorpions part; why would you have a phase problem? Not just eq?
Swap your subs polarity to find out if there is a big problem.
// Have you ever tried putting all your subs next to each other spread over the width of the room? (max 2 foot (~ 1/4 wave length) a part if they crossover at 150hz), you will be surprised of the difference this will make.
* It's better to have a system which sounds good and measures bad, then one which measures good and sounds average.*
Old 17th November 2017, 11:36 PM   #94
Originally Posted by Think View Post
Are the drivers broken in before you mounted them? Otherwise the sound will probably become better in next few months of listening...
You have a good point there and I am slightly impatient. 4 of the 12 drivers are new per side and I put 2 on the top and 2 on the bottom of each side. Still no tweeter yet, might not even need them...
...I listened to the scorpions part; why would you have a phase problem? Not just eq?
Another good point. There's a serious issue with the subs the way they're currently stacked... I was aiming for a half array on the subwoofers, but I see this is a very bad idea. I've read pros and cons, but I think I'm experiencing more cons in my smallish room with cathedral ceiling.
I won't be around much next few months as I have new debt, but I'll be lurking . As promised wife is getting new floors for putting up with this project. I'll be doing research on class D amps with built in DSP and bluetooth for driving each P7...
In the future, after 6 months, I do intend to redo the subs, first priority. Might not need 7 foot tall 10" 1/2" thick PVC tubes, but we'll see... Will experiment with push-pull, push-push and pull-pull. Might do some research in the sub section and class D section.
Thanks for y'alls inputs, it is much appreciated!
Old 18th November 2017, 02:48 PM   #95
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Originally Posted by perceval View Post
Maybe you should take a break and read, at least some of, wesayso's two towers adventures.
He thought a lot about what he wanted to do, before starting to build it.
It looks to me like your thinking is all over the place with no direction nor planning.
I'd take a step back, evaluate where you are, study your options and come up with a plan for your place and your setup.
And with line arrays, consider bringing DSP into the fold to help time align all those drivers, phase correction and EQ balance.
I'm pretty sure there is an interesting lecture on its way in this thread:
Infinite Line Source: analysis
So, Dr1v3n, if you still have time to spare, it will probably be an interesting read.
Use Science to design your speakers and they will sound like a piece of Art...
Old 18th November 2017, 03:46 PM   #96
Thanks for the invite! I'll be following along.
What do you guys/gals think of PVC for FR enclosure?Hide this!Advertise here!
Hi Guys, just bought a JBL 1214 GTO ,need help to built a nice ported enclosure kevin22 Subwoofers 3 15th October 2015 02:39 PM
You guys and gals recognize any of this equipment? Sodacose Tubes / Valves 12 7th June 2015 10:25 PM
What do you guys (gals) think of this? aptquark Planars & Exotics 8 15th June 2010 02:41 AM
Hi Pals & Gals messenger Introductions 2 8th June 2010 01:18 AM
All you horn guys and gals Variac Multi-Way 6 17th June 2003 08:27 PM
