Markaudio Alpair-5 Giraffe Build
Old 16th September 2017, 06:19 PM   #31
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
They should be volume filled with well teased poly fluff — the amount determined by listening… more density depresses the low end and reduces the ripple. There is some gain in the bottom so it does need to be damped at least somewhat. Room, room placement, listening preferences all play a roll.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th September 2017, 06:23 PM   #32
chrisb is offline chrisb
Honestly, I've done too many builds to remember - in the case of the A5.2, I think there was a total of 5 different builds, including the Giraffes and FH lites in one week. I would have followed the notes on drawing - which I don't have at hand - probably just some 1/2" UltraTouch felt lining the walls, and some loose AcoustiStuff fibre?
Dave or Scott can confirm those details - which begs the question, was there even an official CAD , or just a gin-soaked cocktail napkin sketch. ?
Old 16th September 2017, 06:35 PM   #33
frugal-phile(tm)
planet10's Avatar
http://wodendesign.com/downloads/Gir...v99-081015.pdf
dave
Edit: i do see that the front view shows the “frame” for a removable back (as in the Pensils), but the side view doesn’t.
Old 16th September 2017, 07:55 PM   #34
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by planet10 View Post
A circular cross-section will have 1 strong side-to-side resonance. A square cyclinder would as well. If filled with damping should not be an issue.
dave
Perhaps, with the circular one, the majority of resonant modes will have peak amplitude at the axial centre of the tube and some damping material at that location could prove particularly effective ??
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th September 2017, 08:03 PM   #35
frugal-phile(tm)
planet10's Avatar
Well yes, i’d stuff the entire cylinder. My ap is most typically midTL and i like to stuff them till aperiodic.
dave
Old 18th September 2017, 05:14 PM   #36
craigtone is offline craigtone  United States
craigtone's Avatar
So far I have found placement with respect to listener more important than room placement. I prefer about 6' from listening position and 6' apart with no toe-in. This seems to give the best balance with decent bass and a VERY wide (~12') soundstage.
Now that they are broken-in a bit, I popped on some Megadeth Countdown to Extinction and Rage Against the Machine Killing in the Name of yesterday at moderate volume and I was blown away! My old Alpair 12 pensils could not keep up with faster music but these little Alpair 5's have NO problem with whatever is thrown at them!
I am currently running them off my 45SET amp and find that I lost dynamics vs the Gain Clone. I am now leaning towards a Pass Amp Camp build for these which I think would be their sweet spot as they did sound phenomenal on my buddies Aleph J when we first tested them out.
Craigtone Audio
DL-110, SL-1200, Pearl 2, Apollo-R, D100 Mk2, Mezmerize, TSE 45, ALK Klipschorns
Old 18th September 2017, 06:55 PM   #37
As sweet a piece as the ACA is, I'm thinking you'll find 10W+ to be the start of the golden zone for these little guys. IIRC, when I did my quickie listening test to the 5 or 6 designs that I blasted together for this driver last year or so, it was with my Tubelab Simple PP EL84 (15-ish WPC) . I can certainly imagine a 45or even 2A3 SET would be a bit light on grunt for these.
Old 18th September 2017, 07:03 PM   #38
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by chrisb View Post
yah, sumpin like that - scottj is currently on a campaign to rid the term FAST from our lexicon, and since I've frequently mentioned my dislike for the term, I should probably support that ?
Good show old bean
Subwoofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Markaudio Alpair-5 Giraffe BuildHide this!Advertise here!
HT Front Stage Designs Using Markaudio Alpair 10.2 - Plans, Feedback and Build Log Ben_Tech Full Range 96 1st January 2015 11:41 PM
FS: Markaudio Alpair 7.3 Tobi F Swap Meet 0 18th September 2014 03:45 PM
Markaudio Alpair 7 FS dhaen Swap Meet 0 8th July 2014 07:49 AM
Need help with matching MarkAudio Alpair 7 gen 2 golgiapparatus Multi-Way 6 21st May 2012 02:27 AM
alpair 5 from markaudio _henry_ Full Range 39 17th August 2008 07:32 AM
Copyright ©1999-2017 diyAudio
