ACA Speaker short list
Old 6th September 2017, 01:49 AM   #21
perceval is offline perceval  Taiwan
perceval's Avatar
But I read the FH series need to be quite off the back wall to work well, which might not be easy if the room is on the smallish side.
They might work, but it will depend on the room's design.
And I also heard good things about the FH series as well from builders here.
Old 6th September 2017, 01:55 AM   #22
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Dayton PA130-8 in a 0.53x Karlsonator. Or dual PA130-8 wired in parallel in and XKi for 95dB at 2.83v sensitivity and capable of a 50Hz to 15kHz performance in a budget driver.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 6th September 2017, 02:12 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
On the contrary, close to a wall or corner is best to be able to use the wall(s) as an extention to the horn mouth. Bass quantity dictated by room, placement, driver, listner preference can be adjusted with the amount of stuffing below the driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th September 2017, 02:53 AM   #24
Skylar88 is offline Skylar88  South Africa
The Dayton PA130-8 in a 0.53x Karlsonator was my first choice until I discovered yesterday that there is a local supplier of FaitalPro. And the prices are so low that I'd be a fool to ignore it. I have a choice between 3FE22 and 4FE32. What do you think is the best option now?
Old 6th September 2017, 04:50 AM   #25
kp93300 is offline kp93300  Malaysia
hi X,
What type of box do you recommend for dual Dayton PA 130-8 wired in parallel ?
You mean use the 16 Ohm version of the driver ?
Old 6th September 2017, 09:15 AM   #26
twocents is offline twocents  South Africa
twocents's Avatar
Originally Posted by kp93300 View Post
hi X,
XKi - X's ab initio Karlson 6th Order Bandpass
Two 8 ohm drivers giving a 4 ohm speaker.
Old 6th September 2017, 03:32 PM   #27
Got Foam?
xrk971's Avatar
Yes, dual 8ohms in parallel for 4ohm speaker that is 95dB at 2.83v. Not bad for $36 in drivers.
Skylar88: if you have ready access to Faital Pro, a dual 3FE25-8ohms in parallel in a 0.53x Karlsonator is quite impressively loud at 97dB and 2.83v. Should sound good as those are smooth drivers.
Old 6th September 2017, 03:56 PM   #28
Thanks X, I was actually thinking to ask you about that. Wow, 97dB.
I can only get the newer (I suppose) 3FE22's. Would they be suitable as duals too? I suppose a single 4FE32 wouldn't be as good in a 0.53x K.
And then a question about mounting the FaitalPro's FR drivers. Seeing that they are rear-mount, would it matter if it's front-mounted? Rear-mounting in a Karlsonator wouldn't be so easy.
Christo
Old 6th September 2017, 04:08 PM   #29
Bare is offline Bare  Canada
Fair chance that the ACA will be 'better' than any speaker you are looking at. When (?) you move up into a bigger Pass amp then you will be needing to replace that speaker. As it Will be an obvious bottleneck.
As in don't waste effort searching for the ideal best speaker.. yet.
Old 6th September 2017, 04:16 PM   #30
Hmm, food for thought, that is.
Thanks Bare. So, what would you suggest as better speakers for bigger Papa amps. Not that I'll build it now. Just curious. And is that because the bigger amps would require less efficient speakers?
Christo
ACA Speaker short listHide this!Advertise here!
Some advice on powersupply for short list amp build Inprogress Chip Amps 3 12th May 2013 10:57 AM
Short list opinions iUSERTLO72p Subwoofers 6 22nd October 2007 03:16 PM
Aurasound speaker for short line array? MPM Full Range 5 6th September 2005 12:51 PM
speaker protection and output short patriz Chip Amps 3 10th January 2005 03:55 PM
Short list of DIY tube amps with PCBs available... wigginjs Tubes / Valves 8 5th November 2004 12:02 PM
