Hello!
This is the plan supposed for Jensen horn speaker with G610.
What do you think having Audio Nirvana Classic 15 alnico with this cabinet?
Fullrange speakers. DIY speakers. DIY Speaker kits. DIY Audio. Open Baffle Speakers. Fullrange drivers. Audio Nirvana, Lowther, Fostex. Vacuum Tube Amplifiers For Sale
Thanks!
Thanks!
What was said above. Not with a Q of nearly 1.0 and a 13.56ft^3 Vas. Even a big horn like the Imperial isn't going to be large enough for quality performance. Same arguments (more so) for the Super 15 AlNiCo.
Therefore, what would happen if having the classic 15 alnico on the Jenson folded horn cabinet? What will be getting affected due to the high qts?
What about modified this cabinet to fit the Classic 15 alnico as the horn cabinet is much larger?
Sub-Woofer
Sub-Woofer
What Freddi shows. Large underdamped peaking in the mid - upper bass, limited output in the lower regions (< 100Hz). Dodgy sound, lots of complexity for not a lot of point.
Leaving aside off-axis radiation & various other practical considerations, it would be marginally better in alignment terms. Marginally. As in how some parts of the RMS Titanic are marginally less underwater than others. But this is not a driver that either benefits from or requires a back horn. It has a mass corner frequency of only 64.28Hz not including any series R present in the circuit.
FWIW, 'gapping' [air leak between driver, baffle] a high Qt driver to 'bleed' off its 'Q-ness' can work, sometimes with/without damping material in the gap, though unless AkAbak can sim it, tuning is strictly empirically derived. Bruce Edgar did it on one of his FLH designs IIRC.
Designed from scratch, Klipsch Rebel concepts work well if there's some well constructed corners or even the DIY ones designed for the Klipschorn if a higher cutoff is acceptable.
GM
GM
assuming JAG's model is ballpark and other than the horrific price for the Radian, the Radian CX parameters are a step in the right direction
2.83V 1Pi
for sensitivity comparison, here's a simulation of my little midbass horn with a $50 driver
plus Klipsch La Scala with K33
2.83V 1 Pi
2.83V 1Pi
2.83V 1 Pi
I think the Radiant drive unit is seriously made with very low Qts.
I guess it should sound better than the vintage Jensen G610.
G610 is a special speaker, not comparable to the others, IMO.
- Full Range
- Jensen folded horn with Audio Nirvana Classic 15 alnico?
