hello
exusme
i not good at english
i make this box
but not good bass
i not have 50hz ferekans
and 200 hz is long and strong and this not good
how this port is long??
what problem??
http://construyasuvideorockola.com/imagenes/amp_20x12/amp_12x20_12.jpg
file:///C:/Users/Tak%20Rayan/Downloads/Documents/amp12x20w.pdf
exusme
i make this box
but not good bass
what problem??
internal dimensions = 23 * 19 * 14
If those are cm then 6.1 litres
excluding the vent?
driver is 6" star pioneer
That looks like a 2-way car speaker. Any T/S numbers?
dave
To up the bass read this thread:hello
exusme
i make this box
but not good bass
what problem??
How to Treat Passively Peaky FullRange Drivers
vent = 30 cm long - 2.5 cm width
A slot vent has a height, width & depth. 1 more dimension needed.
dave
hello
exusme
i not good at English
Don't worry about that. It's probably better than many other people's.
i make this box
but not good bass
what problem??
Without more information it's difficult to say. Was this box designed for the driver you used?
EXUSMEA slot vent has a height, width & depth. 1 more dimension needed.
dave
I NOT GOOD AT ENGLISH
what?!
no i am copy this box from Construyasuvideorockola.com
but a not have driver t/s and i can't design it
http://uupload.ir/files/k87q_photo_2017-08-17_22-42-04.jpg
my problem: freqans is very high , i like low bass and smal kik bass
Once built there are a couple easy things to try.
I think your tuning frequency is possibly too high, something like 81Hz if your port is 2.5x19 on the front of the box (47.5cm^2 area) and 30cm long. Try making the port narrower with pieces of wood, or styrofoam, something temporary. For a 6 liter box you need a port that is roughly 17cm^2 in area to get a tuning frequency of 50Hz when it is roughly 30cm long.
If all else fails, try stuffing the port completely with a shirt.
oh mercyOnce built there are a couple easy things to try.
thanks
2.5 * 19 is big? i most make smal port? 1.5 * 18 is good?!
MERCY2.5 * 7
if i have buy a good fullrang for my room , what speaker is good??? and how folow it in iran?
car speaker is good?! (helix - dragster - rockforde - grand zero)
MERCY
Car speakers are made for cars.
Can you order hifi-speakers from Iran?
I CAN , but its not mark and not have model so have not t/s parametrsCar speakers are made for cars.
No parameter also?
؟؟؟؟I CAN , but its not mark and not have model so have not t/s parametrs
No parameter also?
- Full Range
- full range box
