What Would You Do With These Empty Cabinets? (JBL)
Old 14th July 2017, 09:51 PM   #41
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Bob Richards View Post
[*]At a crossover frequency, due to phase shift created by the reactive components in the crossover, there's a thing called "lobing", which in a practical sense means the direction of projection of the maximum amplitude moves as you go through the crossover frequency region, because of how the two acoustic outputs add in space with their differential delay. If the drivers are configured vertically (usually best), this lobe will sweep vertically as a sine wave is swept through the crossover frequency. This matters because of how the room will react to it. Stereo effect imaging is particularly dependent on balance in the frequency range of about 800HZ - 6kHZ. When lobing occurs any differently on one speaker than the other, and room acoustics will make sure that happens, the stereo effect is compromised, tainted, blurred, left out in the rain…
If the XO is kept below the magic ¼ wavelength of the C-c distance much of this issue goes away.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th July 2017, 07:37 AM   #42
erkd is offline erkd  United States
Originally Posted by freddi View Post
the reason I suggested those Eminence 10 would be to do an Econowave - can't remember if there's room in the L26 cabinet for the waveguide. (will get basic spec on that 10" in a week or so) Deltalite 2510 & Delta 10A have a a ramp up to peak which to contend - it sounds awful just listening to a bare open air driver with pink noise - that surplus EM10 is probably similar. A new Delta 10A runs $69 shipped and with its 2.5" coil, has good thermal properties at higher spl.
Flex Your PCD Mettle: - Techtalk Speaker Building, Audio, Video Discussion Forum
Henry Kloss made wonderful drivers and speaker systems KLH 6 and 17 had nice woofers
A FAST would be interesting - - little Pluvia and a good 10 woofer?
That's right. When I first put these in the closet the econowave was the big thing. Now there's so much more going on I'm having trouble keeping up.
Old 17th July 2017, 02:41 PM   #43
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Planet10 is correct (and thanks for providing the simulations, Dave - I was curious myself).
Erkd, the graphs Planet10 made for you show the predicted frequency response comparing the two 8" Fostex full range drivers. The FF225wk is clearly superior to the FE206En with regard to bass extension in the same box. You can simply take the box you have, replace the front baffle and use the FF225wk with good results. Easy. Maybe Dave will be nice enough to provide the port size for you as well?
Having said that, the other suggestions for multi-way speakers in the box you have are all good - some or all may even be better than simply using the FF225wk. It's all a matter of personal taste and shows how interesting DIY can be.
Old 19th July 2017, 05:48 AM   #44
Planet 10, Godzilla. Thank you guys for your help. I am going to try the 8" fostex driver you recommended.
They are gonna loook so good with the orange grill cloth.
Old 20th July 2017, 08:19 PM   #45
chrisb is offline chrisb
If not already mentioned, note that the FW225 may well need a tweeter - for at least the last 2 octaves?
Old 20th July 2017, 09:16 PM   #46
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
+1
The FF225wk is a wonderful driver, but it really needs help above 8 kHz.
A day without music is like a day without food.
What Would You Do With These Empty Cabinets? (JBL)Hide this!Advertise here!
Empty ABS speaker cabinets MAAC0 Parts 0 16th April 2017 05:28 PM
Free: A bunch of empty speaker cabinets Cal Weldon Swap Meet 8 21st April 2014 10:23 PM
FS - empty speaker cabinets - $20 new2tubes Swap Meet 6 10th July 2012 01:56 AM
Empty molded cabinets? FlipC Subwoofers 19 3rd January 2011 06:48 PM
ideas for my empty Skyline Cabinets punkrokr1701 Multi-Way 4 23rd January 2007 04:44 PM
Copyright ©1999-2017 diyAudio
