SAL Full Range Drivers
Old 11th July 2017, 05:01 AM   #21
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Sims suggest as large a box as you can live with sealed or aperiodic OR open baffle.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th July 2017, 05:27 AM   #22
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
If you want to do it the easy way like Nelson, here are some really nice 1 cu. ft. cabinets from Parts Express
https://www.parts-express.com/dayton...herry--302-753
Best I can figure from the specs they are 208.6 mm wide at the baffle, which is about 8.125" I believe. I think the baffle is solid. It's the bracing that has the 2 holes IMHO so the 8" driver frame should fit. -barely. These are an MTM model, it's a shame they don't seeem to have a "2-way model which are a bit wider.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 11th July 2017, 06:33 AM   #23
frugal-phile(tm)
planet10's Avatar
PE discountined their curved boxes which were OK. My experience with the rectangular boxes is that they need so much remediation you might as well start from scratch.
dave
PS: 1 ft^3 ~ 28 litres which is much smaller than you really want.
Old 11th July 2017, 07:01 AM   #24
diyAudio Editor
Variac's Avatar
I believe the one I linked to is curved, so they seem to still be making the MTM ones.
Maybe that bump gives the illusion of bass!
Probably best plan to make a rough set of bigger boxes about twice the size to test, About the size of a Large Advent, if you go back that far..
Old 11th July 2017, 07:08 AM   #25
frugal-phile(tm)
planet10's Avatar
It is… the smaller ones have disappeared.
The bump is bigger than i’d like and an underdamped response… as well as the real bass extension impacted.
You might get away with mulyiple holes drilled in the back and heavy damping over the holes.
dave
Old 11th July 2017, 07:10 AM   #26
diyAudio Editor
Variac's Avatar
yup. that's pretty bumpy!
Old 11th July 2017, 02:03 PM   #27
WalterW is offline WalterW  Netherlands
I bought a pair SAL08C08 also, subscribed to this thread...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 11th July 2017, 03:00 PM   #28
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
http://www.diyaudio.com/forums/full-...ml#post5128064
Thanks Mr Pass for crossovers schematic share.
Kindest regards
class A amplifiers with full range speakers
sings like angels in heaven
Old 11th July 2017, 05:08 PM   #29
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Originally Posted by Nelson Pass View Post
...OB
with the Eminence 15's.
The Delta-15A's, correct?
Visit AudioMaker.Tech
Old 12th July 2017, 08:25 PM   #30
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Yes, the sims show a bump, but so far it sounds good and chicks dig it...
For the 15", you've got the Beta, Delta, and Definimax, all of which
work pretty well.
TAD 1601's are nice too.
SAL Full Range DriversHide this!Advertise here!
Ohm drivers - can we use full range drivers instead? Godzilla Full Range 2 10th April 2016 01:15 AM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 10:42 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 04:50 PM
Full range drivers. tade Full Range 5 2nd March 2005 02:59 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 10:27 AM
