SAL Full Range Drivers
Old 17th January 2018, 11:18 PM   #201
tommydoan84 is offline tommydoan84  United States
Thank you for the feedback, scottjoplin. I will do things the right way. I will install the drivers to the flat plywood panel and report back what my impression about the drivers.
Tom
Originally Posted by scottjoplin View Post
If the driver is lying flat on the desktop you'd have been getting a lot of very early reflections, you really can't tell what it sounds like in that situation
Old 18th January 2018, 04:46 AM   #202
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
And keep the panel at least a meter from the front wall and the panel vertical, ie the drivers pointed at you.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 11th February 2018, 02:46 PM   #203
A few updates
- Ideas: inspiration from PureAudioProjects and laverda. I used 2 Eminence 15 Beta and SAL driver for OB model
- Xover: Using Frank's passive model
I finished 1 set of OB and have an audition last night. The sound is not what I was expecting it to be. The sound is very thin, imaging and soundstage is collapsing. There is a little bit bass but not much. The sound is not airy and open, it sounds like there's a big curtain or a wall in front of the drivers.
I even used a U frame model and pull the speaker 1 or 2 meter away from the wall but the sound is not improving.
This is the 1st time that my DIY experience is somewhat discouraging and not what I expected to be after so much effort, time and money spent. However, I will continue to try different thing if there is any to really improve sound much further. I know and I can feel it's almost there just a little bit of push to get there
I have a few things that I'm thinking to try
- getting a miniDSP UMIK-1 Omni-directional to measure out the frequency response of the OB driver
- Trying out Nelson's passive Xover to see if it makes any difference
- Remove the 2 wings
- Last: trying out active crossover and bi-amping. I was hoping to get good result with passive Xover first to use it as a reference before going to active Xover
If you have ideas or suggestions, please let me know.
Appreciate the inputs as always.
Best,
Tom
[IMG][url=https://flic.kr/p/24fLgSn]Click the image to open in full size. [/IMG]
[IMG]Click the image to open in full size.My_OB03 [/IMG]
[IMG]Click the image to open in full size.My_OB01 [/IMG]
[IMG]Click the image to open in full size.My_OB02[/IMG]
FW PASS Aleph J, F4, B1, B3, ACA, Pearl 2 Phono Preamp, CNC phono pre, RJM PhonoClone 4.4s.
Old 11th February 2018, 06:04 PM   #204
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
I have that same Maxell poster, and am currently using the same amp.
From the picture of the back of the baffle it looks like you need to relieve the back of the driver cutout.
An example attached.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th February 2018, 06:25 PM   #205
Thanks for the feedback Dave!
You mean I need to remove the left and right wing of the baffle, right?
Tom
dave
Old 11th February 2018, 06:35 PM   #206
silasmellor is offline silasmellor  Denmark
I think he means you need to chamfer the driver cutout of SAL to let it breathe.
Old 11th February 2018, 06:36 PM   #207
frugal-phile(tm)
planet10's Avatar
What Silas said.
dave
Old 11th February 2018, 06:51 PM   #208
bk856er is online now bk856er  United States
bk856er's Avatar
Just to further clarify, a roundover bit with a router is the usual method.
But can this really make such a remarkable difference?
BK
Old 11th February 2018, 07:00 PM   #209
frugal-phile(tm)
planet10's Avatar
We use a 45į bit to get an even greater relief. It can make a considerable difference, removing an oil can resonance and reducing early reflections back thru the cone.
dave
Old 11th February 2018, 08:03 PM   #210
bk856er's Avatar
The 45 bit makes sense for even great relief, especially if there's enough thickness left to securely attach the driver.
I scrolled through the thread and noted that the none (?) of the examples used a backside relief. Some also mounted the driver inset and flush with the baffle, and some simply attached it to the baffle. What are the best practices here? I usually do both.
I'm not building this speaker, at least not yet, just curious...
BK
SAL Full Range DriversHide this!Advertise here!
Ohm drivers - can we use full range drivers instead? Godzilla Full Range 2 10th April 2016 01:15 AM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 10:42 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 04:50 PM
Full range drivers. tade Full Range 5 2nd March 2005 02:59 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 10:27 AM
