SAL Full Range Drivers
Old 12th January 2018, 03:49 AM   #181
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Post #21. 80 litres (unstuffed) give a Q=1. Going bigger doesnít get you much lower. Stuff it well and if you find the bump=up at the bottom too much, start drilling an arrary of small holes in the back at the bottom. See post 164.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th January 2018, 01:19 PM   #182
aoc is offline aoc  Malaysia
dave
Thanks for the reminder Dave... I completely forgot about that post. I will try it out sealed then drilled
Old 12th January 2018, 07:38 PM   #183
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I believe that simulation was done with the old/wrong Thielle-Small parameters. Can you repeat the simulation with the new/correct parameters?
[ audioroot.net | hifibau.ch ]
"You have no clue of how an amplifier works." - AndrewT
Old 12th January 2018, 09:40 PM   #184
frugal-phile(tm)
planet10's Avatar
Where are the correct parameters, please?
dave
Old 14th January 2018, 10:39 AM   #185
Frank40 is offline Frank40  Denmark
Frank40's Avatar
dave
scandinavianaudiolabs
Please note that the Fo and the Qtes will be lower ones the driver has been broken in.
Old 14th January 2018, 10:46 AM   #186
Frank40's Avatar
Originally Posted by aoc View Post
I just bought a pair of SAL... Can't wait to try it when I bring it home to Penang.
Frank,
I got a seal box about 80l would that be a good fit for sealed box?
Yes, I have got good results from large closed boxes.
Old 14th January 2018, 10:54 AM   #187
frugal-phile(tm)
planet10's Avatar
Qt, Fs not significantly changed from before so the curves are the same but the much smaller Vas yields much smaller boxes… 72 litres for Q = 0.9, 32 litres for Q=1.0. Larger boxes will push Q lower but to reach the natural unloaded Q you probably need to use the room on the other side of the wall.
dave
Old 14th January 2018, 08:43 PM   #188
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
I've completed my testing. Here's your chance to snag a pair for half-price.
Scandinavian Audio Labs SAL 08C08 (PAIR)
Inlcudes Nelson Pass filters from his 2015 BAF talk if you want them.
My measurements (for these actual drivers) can be found here:
Measuring SAL | AudioMaker
Visit AudioMaker.Tech
Old Today, 08:03 AM   #189
tommydoan84 is offline tommydoan84  United States
hi Frank and all,
I bought a new pair of SAL from a member of this forum unopened box. I opened it today and hook the driver units by itself to my system to see how it sounds before adding in subs, tweeters, Xover, etc.
My experience is a bit different with some of the people in this thread. I was expecting a really nice sounding, large sound stage and dynamic range out of these units going from low to high freqs; however, the 2 units is lacking alot of bass and the highs. When the music hitting the hight notes it sounds really distorted and peaking(hurting my ears). My system is DIY FW F4/BA3 preamp combo. I also had Aleph J amp and the sonic result is the same with the SAL units. When I switched back my system back to the 3 way JM Focal lab speakers, it sounds nice again so it's not my system that causing these distortion that I experienced.
Does anyone else have the same experience with mine ? Should I start my project by adding in sub and Xover circuit hoping it will improve the sound later on ?
I did not use any type of Xover, filter for my 1st listening test. I directly connect output of the FW amp to both of the drivers. Am I doing anything wrong ?
Thanks,
Tom
SAL Full Range DriversHide this!Advertise here!
Ohm drivers - can we use full range drivers instead? Godzilla Full Range 2 10th April 2016 02:15 AM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 11:42 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 05:50 PM
Full range drivers. tade Full Range 5 2nd March 2005 03:59 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 11:27 AM
