How to design wall mounted speakers?
Old 3rd June 2017, 06:15 PM   #1
osssyvan is offline osssyvan  Finland
Question How to design wall mounted speakers?
Hey,
I was thinking of re-using my TB w5-2106 to wall mounted speakers. They are now in open baffle but after moving I ran out of space for OBs.
I think I am aiming for something small and use a sub to compliment. Is there something to take in to consideration on wall mounted? Different baffle step compensation?
Also I haven't tried designing any speakers in a long time so I could take some suggestions on what program to use. Unless someone already has a good idea on what size would work with those TBs.
BR,
Ossi
Old 3rd June 2017, 06:40 PM   #2
cbdb is offline cbdb  Canada
The biggest problem with most commercial in walls is they use the wall cavity as an enclosure but there is no consistentcy in that size etc. Put your speakers in a box before you put it in the wall.
Old 3rd June 2017, 06:41 PM   #3
Unless the wall behind is open than you can do open baffles.
Old 3rd June 2017, 06:47 PM   #4
Thanks for the ideas.
I am looking for on wall and open baffle could be interesting.
-Ossi
Old 3rd June 2017, 10:59 PM   #5
suprf1y is offline suprf1y  Canada
This won't tell you how to design them, but it should give you some ideas
VIFAntastisch ! Der Wandlautsprecher, Projekte der Nutzer / Eigenentwicklungen - HIFI-FORUM
Old 4th June 2017, 01:44 AM   #6
perceval is offline perceval  Taiwan
perceval's Avatar
Or something like Jordan shows here, just use a single driver and a smaller enclosure.
File Type: png Screen Shot 2017-06-04 at 9.46.22 AM.png (83.6 KB, 259 views)
Old 4th June 2017, 02:00 AM   #7
GM is offline GM  United States
GM's Avatar
The best on-walls I've done were shallow and the baffle tapered back to the wall on each side [bonus points if you do the top and bottom also ]. My few didn't and were all vented with slits between the baffle and back plate.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th June 2017, 11:51 AM   #8
midrange is offline midrange  United Kingdom
Very different BSC. Often none needed at all. I have never made them, but I respect the views of those who rate the Cornu horn. This is a wall mounted design which is pleasingly different. You will find a lot about it on this site.
Old 4th June 2017, 12:07 PM   #9
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Here is something I did a while ago:
http://www.diyaudio.com/forums/full-...ml#post4028642
The wall eliminates need for BSC so you will get the best bass sensitivity compared to other types of mounting.
Another one is this:
Foam Core Board Speaker Enclosures?
And here:
http://www.diyaudio.com/forums/full-...ml#post4472884
And finally, the Cornu back loaded horn:
http://www.diyaudio.com/forums/full-...w-you-can.html
Old 16th June 2017, 10:28 AM   #10
Thanks for great links.
I think I'll start with simple sealed design. What software would you suggest to use ?
I am thinking of making it wall art with some printed cloth on it. I think something shalllow that would match acoustic panel sizes. I could then hide them quite nicely.
-ossi
How to design wall mounted speakers?Hide this!Advertise here!
Wall Mounted Speakers? Philosophil Full Range 45 30th October 2013 11:03 AM
Design of wall mounted bipolar surround speakers? Whistler Multi-Way 3 24th September 2010 03:19 PM
Flat wall mounted speakers CCU Multi-Way 9 10th September 2009 06:05 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
DIY wall-mounted speakers Donut Multi-Way 4 16th September 2002 06:10 AM
