Custom DIY 8" Fullrange Driver
Old 3rd June 2017, 11:43 AM   #21
ghemml is offline ghemml  Singapore
ghemml's Avatar
Originally Posted by ICG View Post
Well, that's not why you want the whizzer big. The whizzer does radiate hights but - like a large dome- or cone-tweeter, the narrower it goes on the top end. And on the lower end of the whizzer, you usually want to 'start' where the cone starts to drop off. Or, to be more precise, where the breakup starts. Since you can correct the response passive but cannot correct the radiation pattern (not even with a DSP), naturally, the radiation pattern is what dictates the size of the whizzer.
Cone breakup makes me want to use a thinner paper for the whizzer cone.
But still just ran a DCR measurement... its 8.7ohms
So 0.14mm VC wire is not suitable, probably had to use 0.15mm
Old 11th June 2017, 02:36 AM   #22
ghemml's Avatar
Just got back, did some test measurements on the TS parameters. And I discovered I had used the wrong wire gauge, and the Re values is abit too off.
But anyway the drivers are measured, since they are just prototype I will have to keep in mind using the correct gauge for the VC during the next round of fabrication.
Click the image to open in full size.Click the image to open in full size.
Old 11th June 2017, 03:05 AM   #23
Upfront is offline Upfront  Australia
Upfront's Avatar
We live and learn. Beautiful work so far mate.
Old 11th June 2017, 03:17 AM   #24
ghemml's Avatar
Thanks.
I must say, it is very difficult to measure small gauge wires DCR. The thin ends contacts makes it very difficult to crimp with crocs clips and I always end up values that are not constant
This is the measurement I got from WT3
* Piston Diameter = 160.0 mm
* f(s)= 63.93 Hz
* R(e)= 8.86 Ohms
* Z(max)= 392.40 Ohms
* Q(ms)= 12.015
* Q(es)= 0.277
* Q(ts)= 0.271
* V(as)= 31.150 liters (1.100 cubic feet)
* L(e)= 1.16 mH
* n(0)= 2.80 %
* SPL= 96.57 1W/1m
* M(ms)= 11.30 grams
* C(ms)= 0.55 mm/N
* BL= 12.05
Old 11th June 2017, 03:28 AM   #25
Upfront's Avatar
Very difficult. I don't envy you in that respect. But where there is a will, there is a way. Keep up the good work.
Old 28th June 2017, 03:50 PM   #26
ghemml's Avatar
Super busy with work lately but finally got to assemble my 8 inch prototype and get it ready for the Audio Show in KL in July
https://youtu.be/eFzjlTlpdFY
Will perform measurement this weekend as I got matters to attend.
Old 28th June 2017, 04:08 PM   #27
perceval is online now perceval  Taiwan
perceval's Avatar
Looking very nice.
Love the color scheme.
Experimenting with different feet options?
Old 28th June 2017, 04:28 PM   #28
ghemml's Avatar
Originally Posted by perceval View Post
Looking very nice.
Makeshift footers, LOL.
Old 2nd July 2017, 04:12 AM   #29
ghemml's Avatar
A quick measurement I made:
Freq Response
Cumulative Spectrum Decay
After Baffle Step Correction
Old 4th July 2017, 08:53 AM   #30
hm is offline hm  Europe
hm's Avatar
Default superb driver
well done, i would try it in my saxophon or RDH20, with invers driver, for show and sound,
you fill ~6 dB up to 2 kHz, bass down 30 Hz and minimal lenar membran moving, plan for free if you will test it.
http://www.hm-moreart.de
Custom DIY 8" Fullrange DriverHide this!Advertise here!
Custom DIY 6.5" Fullrange Driver ghemml Full Range 133 22nd July 2017 02:35 PM
Making my own custom low tech 12" fullrange from an old Akai woofer:) impuls60 Full Range 3 5th December 2011 11:19 PM
Pioneer 4.5 fullrange driver ("A11"): $20/each gychang Swap Meet 0 4th September 2011 08:52 PM
Interesting Cheap - possible "fullrange" eff. driver ScottG Full Range 1 27th March 2006 11:28 PM
DIY fullrange driver? Nappylady Full Range 24 25th February 2004 02:17 PM
