Benefits of a TL-TQWT over a MLTL? - diyAudio
Old 18th May 2017, 06:00 PM   #1
Bill poster's Avatar
Default Benefits of a ML-TQWT over a MLTL?
Not many recent ML TQWT builds, but for drivers with an Fs around 45hz the line length is suitable, not too long.
Am i right in thinking the main advantage is an increase in SPL, seeing as its a type of (mass loaded)horn?
Old 18th May 2017, 08:33 PM   #2
Scottmoose's Avatar
An ML-horn (or what GM and I describe as such, although it seems we are dinosaurs) has a broader gain BW than an untapered ML pipe, so that may be useful for some drivers with a higher mass corner frequency.
If you will excuse me, I am now off to amiably masticate some tree-tops.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 18th May 2017, 08:47 PM   #3
Sorry be a dinosnore but what's BW?
Old 18th May 2017, 08:59 PM   #4
zman01 is offline zman01  Bangladesh
BW=Bandwidth?
Old 18th May 2017, 09:04 PM   #5
drewan is offline drewan  United Kingdom
BW? i don't know but I do know I love small TQWTs, My intro to diyaudio was a faital pro 4fe35 in a MH audio site designed TQWT. They still astonish me how good they are... and for £24.....2 yrs ago. I like broccoli too!
Old 18th May 2017, 09:20 PM   #6
Scottmoose's Avatar
Originally Posted by zman01 View Post
BW=Bandwidth?
Right.
Old 18th May 2017, 10:48 PM   #7
GM is offline GM  United States
GM's Avatar
If one breaks down the range of usable T/S specs for vented alignments into three segments, then low[er] Qts drivers that require an acoustically small cab [Vb] with a long vent could be morphed into an inverse tapered TQWT to get a sufficiently long, large vent area [Av]; then conversely, an expanding, vented [mass loaded] ML-TQWT [I like to define them as ML-horns] will work well for high[er] Qts drivers that require a large [Vb] with a short, large [Av], leaving the simple constant [straight] tapered ML-TL to cover the ~0.31-0.52 Qts range where a ~0.4 Qts yields a Vb = Vas, Fb = Fs alignment.
Of course any of these pipe alignments can be used over the entire range of Qts if the needs of the app [or personal preference] dictates it, so strictly a guideline.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th May 2017, 11:38 PM   #8
GM,
Greets!
If I understand correctly - a mid-woofer with following specs would be a candidate for a Inverse tapered TQWT?
Fs - 30 Hz
Qts - 0.27
Qms - 4.90
Qes - 0.29
Sd - 95 cm²
Vas - 27.4
Designs I have come across using this driver are usually small bass-reflex boxes (12-15 liters) and longish vents (~8").
If this driver were used in a TQWT, what would the box dimensions be like, and in terms of bandwidth gains, what can we expect vs the smallish BR cabinets?
Old 19th May 2017, 02:01 AM   #9
frugal-phile(tm)
planet10's Avatar
You can also use ML-TL vrs ML-Voigt to change the aspect of the box. Scott did an ML-TL for us to use as a woofT for the uFonkenSET.
That performed so well, i wanted to do a FAST with the same FF85wKeN but with 4 woofers per side. Also, inspired by the KEF blades i wanted the woofers to be above & below the midTweeter. This required a taller box, so i had Scott do an ML-V for it. On the left (Bernie has since skinned them in Yew, but we are still detailing them), next to the FH3.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th May 2017, 03:09 AM   #10
xrk971 is offline xrk971  United States
xrk971's Avatar
The mini Karlsonator thread has lots of ML TQWT builds as of late if you look in the thread. I am guessing maybe 50 happy builders of the mini (or larger) Karlsonators - a super versatile GregB design. Works very well with moderate Qts drivers.
What's the difference between a TL, a ML-TL and a TQWT? Bricolo Multi-Way 85 18th September 2014 07:15 AM
MLTL v. ML TQWT drongo Full Range 23 23rd January 2013 03:05 PM
MLTL vs TQWT, 206 vs 207 AuroraB Full Range 10 7th October 2011 04:47 PM
TL, MLTL, or TQWT with Lyeco drivers? BottleheadMan Full Range 1 10th March 2010 11:49 PM
FE167e: Brines MLTL or folded King ML TQWT? roundel325 Full Range 5 15th October 2006 05:19 AM
Copyright ©1999-2017 diyAudio
