help with FAST setup
Old 17th August 2017, 01:55 PM   #41
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Ground loops from a PC can be a problem that is hard to get rid of. I tend to use laptops and when in total fruistration, I run on batteries and disconnect from mains.
Try to not connect ground shell of 3.5mm or RCA jacks to earth/chassis GND directly. They should be connected to just signal GND on PCBs. PCB signal GND (clean ground) should be connected to Earth/chassis GND (Dirty gorund) via a 10R (ground loop breaker) resistor. Add back to back diodes in parallel for safety. There is a nice whitepaper here on tricks:
Audio Component Grounding and Interconnection
Grounding and Shielding for your DIY Audio Projects
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 17th August 2017, 03:41 PM   #42
twoNibbles is offline twoNibbles  United States
Thank you! I have been searching and searching for articles like the two you linked even before I ordered my boards. This gives me a pretty nicely itemized list of things to do and the order in which I should try them. I will check back in when I have success or lack of success to report.
Old 20th August 2017, 12:37 AM   #43
Ok first check on the itemized list was the one I thought was the most likely to work and indeed it did!
The biggest problem with what I was doing was providing a separate ground path to the XO board for each channel. by combining these ground paths for input, low out, and high out respectively the buzz is totally gone. This makes me super happy!
Now I need to put my active xo project in a plastic box. I'm going to draw a box for it and have my bud 3d print it. I plan on leaving this project as a floating ground. I don't see anything wrong with that unless you all want to talk me out of it. Using a plastic box I don't see much merit in a safety ground. I guess the RCA ground could become hot?
Next part of my project is testing the response with software and a mic. I would love direction to any resources you guys have used on this topic. In the mean time I'll be looking into that myself.
Thanks guys I certainly wouldn't have gotten this far without your guidance!
Old 20th August 2017, 08:08 AM   #44
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hello again, you have been busy! Glad you are making progress. A couple more links on grounding for you, the first is by member Bonsai
http://hifisonix.com/wordpress/wp-co...-Autosaved.pdf
http://www.updatemydynaco.com/docume...lemsRev1p4.pdf
D. Joffe is also a member
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 14th April 2018, 08:20 AM   #45
twocents is offline twocents  South Africa
twocents's Avatar
Default Progress ?
Hey twoNibbles, what happened to this project? Would like some feedback please.
help with FAST setupHide this!Advertise here!
Small OB in a FAST setup perceval Full Range 53 17th February 2017 11:28 AM
FAST and a 3 way....? Jerms Full Range 7 31st May 2016 12:15 PM
A fast way to build FAST solhaga Full Range 36 15th December 2012 10:32 AM
help fast ! v1d9uy Full Range 3 12th January 2006 10:15 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
