help with FAST setup
Old 12th April 2017, 02:46 PM   #21
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The other potential problem which is touched upon there is the low load impedance to the source with the high pass filter which can cause roll off at high frequencies, most modern sources won't have a problem with that but if you are adding a pot for level matching then it would be best to use a buffer after the pot. Then you are halfway to an active filter........
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 12th April 2017, 03:04 PM   #22
twoNibbles is offline twoNibbles  United States
I had thought about an active filter. I am not a fan of op amps though. They are... finicky. "Close enough" engineering doesn't really work with them as they tend to amplify the difference. Also I don't really want to mess with making a PCB. Nasty chemical process I'm not a fan of or an expensive long wait from a contract MFR. Big passive components are nice and easy.
Old 12th April 2017, 03:13 PM   #23
Boden is offline Boden  Netherlands
Dear twoNibbles,
Before worrying about opamps, there is is whole Universe in other priorities to right first. The first priority is trying to get your filtering in order, be it passive or active, which will require in-box measuring the drivers SPL curves plus impedance curves, and then using these in a simulation tool such as XSim.
Before, or rather without that, the whole thread will lead to a lot of handwaving. Not to a solidly designed system. There is no short cut, I am afraid.
Good Luck,
Eelco
Old 12th April 2017, 03:15 PM   #24
Any level matching will effect the filter, but this can be taken into account in the design and so long as its something which is not adjusted later you can find a work around.
As an aside, I've just finished building Doug Self's preamp with adjustable tone controls. It uses 15 dual op amps and a multitude of electrolytic capacitors in the signal path.... the kind of thing that gives some people here nightmares
Old 12th April 2017, 04:23 PM   #25
Is this really necessary? Is it impossible to arrive at a decent system without a mic and a simulation software? My gut tells me that something of reasonably high quality can be achieved via a mixture of research, listening, and tuning. I have no doubt that the way you are suggesting is the correct way but this is just my first speaker project. I am starting from nowhere. With nothing. As I build projects I will gain tools and education that will aid me in operating to your level of exactness but for now I want a reasonably successful speaker system that I can listen to and enjoy while I work on making another one to do an even better job with somewhat more educated approach from the beginning. Is this such a terrible approach?
edit: My intention is not to whine at you but honestly ask. You truly don't believe that I can attain something satisfactory in this way?
Old 12th April 2017, 06:09 PM   #26
Yes, I am convinced (and so do Vance Dickason, Joe DÁppolito. John Kreskovsky Siefried Linkwitz and many many other serious designers) , although many here seem to think otherwise.
Old 12th April 2017, 06:15 PM   #27
I suppose I will have to find out on my own as I am not convinced.
Old 12th April 2017, 07:15 PM   #28
If you were designing a system from scratch, and particularly if you were using a high level crossover and multiple drive units, then I would agree with Boden, but that is not the case. For what you want to do ie, add a subwoofer to a full range speaker (FAST) that approach is not necessary in order to achieve the improvement you're after.
Old 12th April 2017, 07:21 PM   #29
That is what I thought. I'm not doing anything overly complicated here. Maybe I'll take on some ridiculousness in the next iteration but this seems overly exacting for my purposes at the moment.
Old 12th April 2017, 07:23 PM   #30
chrisb is offline chrisb
I think there's room in this sandbox for us to agree that both methodologies - the scientifically rigorous and the iterative "let's see if this works" - can yield results that will ( at least temporarily) satisfy the ears and pride of the builder.
like my mind, this space intentionally blank
help with FAST setupHide this!Advertise here!
Small OB in a FAST setup perceval Full Range 53 17th February 2017 11:28 AM
FAST and a 3 way....? Jerms Full Range 7 31st May 2016 12:15 PM
A fast way to build FAST solhaga Full Range 36 15th December 2012 10:32 AM
help fast ! v1d9uy Full Range 3 12th January 2006 10:15 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
