Mini Tower Line Array using Pluvia 7's
Old 13th February 2018, 04:29 PM   #201
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by Dr1v3n View Post
ICG thx! You are familiar with Audiosource?
The Audiosource Amp 3 is not currently in bridge mode (Although you do see 2 Amps in the pic )... Thanks for the warning... I'm going to rewire the subs for 4 ohms, since I'm using the one amp. I am aiming to have the second sub done in a few days and raize God almighty hell. Forgive me
No but I've read the datasheet. And I've repaired a lot of amps. Quadrupling (or more) the drawn current isn't something amps are excited looking forward to. And the protection does not always work as good as expected.
I had a Déjà Moo - I've seen that BS before!
Old 13th February 2018, 04:43 PM   #202
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
What is the benefit to single strand over multi strand? Lower capacitance? Lower inductance?
It breaks more easily
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 13th February 2018, 09:07 PM   #203
chrisb is offline chrisb
Indeed, the output devices and/or power transformer may fail to protect the mains fuse. All kidding aside, there is no warranty against the product being used outside its safe operating area.
kinda burnt out - taking a break
Old 13th February 2018, 11:00 PM   #204
Dr1v3n is offline Dr1v3n  United States
Indeed. When I was wiring up the right side array, 1 wire did break during the stuffing phase on 1 speaker. I guess I got lucky. None of the PVC was glued so I could disassemble, rewire and reassemble. No plans to glue either
Old 13th February 2018, 11:08 PM   #205
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The wire usually breaks because you nipped the wire when stripping it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2018, 04:19 AM   #206
dright is offline dright
Dr1v3n and all the contributing members, I'd like to think you all for this fascinating discussion. Although I joined this forum several years ago, I've not visited until recently. I read the whole thread. It was quite a journey!
Sir, I live in Cary. Maybe I can visit you sometimes ;-)
Old 14th February 2018, 07:49 AM   #207
If you use solid core something thicker would be better. Mains twin and earth has been used successfully as speaker wire
Old 14th February 2018, 02:29 PM   #208
I've used 12AWG solid copper originally. The gauge was typical of 120c AC household wiring. But I think Dave might be on to something with the skin effect frequency transmission with thinner solid copper wire.
Old 14th February 2018, 02:35 PM   #209
Glad you enjoy the thread and welcome back. You live in the containment area for relocated yankees? I used to work there. PM if interested
Old 14th February 2018, 04:04 PM   #210
Wire ain't rocket science or voodoo - but yes the thinner solid core is easy to nick if you don't have an appropriate stripper.
Mini Tower Line Array using Pluvia 7'sHide this!Advertise here!
Aura NSW2 mini line-array CC - good idea or bad? jReave Multi-Way 12 3rd April 2017 09:58 PM
2-way mini tower Byronkoeder Multi-Way 25 25th March 2014 03:37 AM
Alpair 12P mini line array advice clivetjm Full Range 7 14th February 2014 06:46 PM
fostex based mini line array MPM Full Range 11 4th November 2009 11:06 PM
Bass Array Tower jtwrace Subwoofers 19 2nd March 2007 03:07 AM
