Transmission Line Speaker Build using Alpair 7.3 speakers, first build.
Old 18th March 2017, 12:17 AM   #1
vishalk is offline vishalk  United Kingdom
vishalk's Avatar
Default Transmission Line Speaker Build using Alpair 7.3 speakers, first build.
Hi All, thought i would share my work so far! Ill write more later on to accompany the pictures on here, but these should give you a good idea of what i have been up to!
Old 18th March 2017, 04:18 PM   #2
zacster is offline zacster  United States
Wow, very nice. I'd really be curious about how they sound. I have a pair of 7.3 in the FH cabinet, but my build wasn't so great so I'm thinking of something else for them.
So, did you create a router template for the cutout and do the layers individually?
Old 18th March 2017, 05:18 PM   #3
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Was this designed for the A7.3 driver or was it borrowed from the commercial one for a Fostex I have seen somewhere on a Japanese website?
Old 18th March 2017, 06:04 PM   #4
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Pretty adventurous for a first build, well done
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 19th March 2017, 01:41 PM   #5
vishalk's Avatar
Hi Zacster, these were made on a CNC router by a gentleman in France called Christian Pop, yes each part was cut and then layered. All i had to do was glue and clamp them.
Ill post the results of the frequency response and testing i got from REW with my mini dsp mic.
But presently they sound wonderful and surprisingly the bass is clean and present!
Old 19th March 2017, 01:47 PM   #6
vishalk's Avatar
Hi xrk971
These were designed around using the Alpair 7.3, Parameters were Qts 0.4-0.6 and Fs between 70 - 80hz.
I've always wanted to try this type of design as i have built a few normal bass reflex boxes. I also wanted them to be efficient as i am using a valve amplifier with only 3.5w of power.
Not only that with the use of CNC routers makes this type of build possible and easier to construct. I was very impressed by the build, obviously it needed some work but that's the fun of it.
Old 19th March 2017, 11:54 PM   #7
vishalk's Avatar
Default REW speaker testing
In order for me to really know how these speakers sound i wanted to do some loudspeaker measurements.
I didn't want to spend a great deal of money so with some research i invested in the mini dsp UMIK-1 and the brilliant free software REW (Room EQ Wizard)
https://www.minidsp.com/applications...r-measurements
I used a DAC Modi from Schiit Audio connected to a class D amplifier.
What i wanted to see was how different types of wadding and also placement of wadding had an effect on the characteristics of the loudspeaker.
I did this until i got the sound i liked and the response i though was better (based on the SPL and phase).
The first measurement is just the loudspeaker in the box with no wadding.
This next screenshot is with wadding compared to without
This screenshot is a mixture of all the different waddings.
Any advice or tips would be most welcome!
Old 20th March 2017, 03:31 AM   #8
perceval is offline perceval  Taiwan
perceval's Avatar
It's fun to take measurements right in front of the speaker and see how they work.
But, ultimately, you'll want to place them in your room, put the mic at the listening position and level, and measure from there.
Playing with speaker position, you'll probably see that huge 10k shelf disappear.
Old 20th March 2017, 04:06 AM   #9
chrisb is offline chrisb
Perceval - while I think you're right about the measurement set up as shown being problematic, what I'd be far more concerned about is the crazy almost 30dB spike centering at 200Hz - which is almost exactly the wavelength of the 1.7m noted as length of the line.
Something very similar to vishalk's measurement is seen in MA's published graphs - although the to not quit the same extreme, and FWIW it should be noted that the latter extend to 40Kz
I've used this driver in literally dozens of enclosures from 6liter sealed ( great for desk-top, but they deserve better IMO)Woden Maeshowe, Pensil, Frugelhorn, several MarKens, custom FASTs, etc. They are definitely capable of much better low frequency response than that shown in the measurements here.
kinda burnt out - taking a break
Old 20th March 2017, 04:24 AM   #10
perceval's Avatar
True.
There's something fishy happening between 160 and 260Hz.
Phase inversion?
Plus, it's a free fall drop below 100Hz... I have a few 4" drivers in MLTL and they can reach 50Hz easily.
Transmission Line Speaker Build using Alpair 7.3 speakers, first build.Hide this!Advertise here!
My first build - Affordable Transmission Line spiralled Loud Speaker Sparrowlegs Full Range 122 5th March 2016 07:56 PM
Transmission Line Speaker Build aanscombe Multi-Way 0 1st June 2014 11:14 PM
Transmission Line Build and Play tpelvis Multi-Way 15 23rd March 2013 08:37 PM
Build Replica IMF Transmission Line Speakers??? Strummer61 Multi-Way 20 28th December 2011 06:20 PM
how to build a transmission line e-side Multi-Way 4 15th July 2005 08:24 PM
