Is it sensible to use a sub to relieve effort from a single driver BLH? - Page 3 - diyAudio
Old 20th March 2017, 12:50 AM   #21
Whoa!!! Chill.
SMathews
Originally Posted by fb2017 View Post
Yeah, unfortunately I don't really think that people using porcelain insulators for the cables, and say that "black CDs sound better" have any idea about how to design speakers either. They totally lost me here: "But that's not the end of this tweak. As the story goes, in order to get the best transfer to a black disk, you need a dedicated laptop with an external CD burner. And during the burning process, the laptop runs off its battery. "
Geez -
Old 20th March 2017, 06:17 AM   #22
Old 21st March 2017, 05:05 AM   #23
hugz is offline hugz  Australia
Do you ever get that weird feeling, like your thread may be in the process of getting derailed?
Anyway, I'm not playing window shaking bass or anything, but even some classical music can get the drivers vibrating quite hard sometimes. I was listening to some Tchaikovsky and was again wondering if any of the highs/mids are being distorted due to the lows.
I'm looking into FAST now though.
Old 21st March 2017, 05:15 AM   #24
GM is offline GM  United States
GM's Avatar
Absolutely! Frequency and amplitude modulation distortion [FMD, AMD] is very real, especially in 'FR' driver reproduction: https://www.klippel.de/fileadmin/kli...Distortion.pdf
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st March 2017, 09:08 AM   #25
scottjoplin's Avatar
Bare i mind lowest A on the piano, fundamental is 27Hz. Ok, not played very often but consider what happens when the sustain pedal is used. One example why, for accurate reproduction, you need the low frequencies. I think you are making the right choice, you have nothing to loose.
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 21st March 2017, 10:52 AM   #26
I have a similar layout, with a Bastanis 12" running full range. The sub has a lowpass filter, the Bastanis runs without a crossover.
I would only consider a high pass crossover, if it was in the digital domain, before amplification.
Otherwise it compromises the benefits mentioned by Scott Joplin, above.
Sent from my Nexus 6 using Tapatalk
Old 22nd March 2017, 10:29 AM   #27
To add something constructive to the thread :
Yesterday I added the Alsa equalizer module to my Raspberry Pi IQAudIO player, and tried to see if there is any potential for raising the bass in my Dallas II. In order to try and keep the digital distortion minimal, I attenuated the mid and high bands, mirroring the response curves I got with measuring with REW.
This reduced the volume, which was compensated by increasing the volume with my amp.
I can say that the Dallas II has a lot of potential for stronger and very tight bass at quite loud volumes (estimated up to 10-12W, which is more than enough for a 98dB speaker). Go much louder than that might cause the FE206En to audibly distort). So there are some reserves that can be exploited and adjusted to taste.
Personally I do not like listening to bass heavy music, and I like to keep the soundpath as pure as possible. So after playing a bit (30 minutes) with it I turned off the equalizer and returned everything to normal. Maybe someone with more time can experiment longer with it and report back..
Old 22nd March 2017, 11:42 AM   #28
picowallspeaker's Avatar
That's what a crossover does. This minimizes "what GM said", [FMD, AMD]
Search also for "pistonic behavior" of a loudspeaker, in order to comprehend why three different sources ( wf/mid/tw ) can work together when put in their passband working region
Everything under and above heaven is in utter chaos
Old 22nd March 2017, 11:54 AM   #29
Actually a crossover tries to completely erase the not needed bands. I just slightly reduced (attenuated) the mids and highs a few dB. The system is still fullrange, but with a bit of focus on bass. Anyway. for the Dallas II, measurements show that above 200Hz, the horn has close to no influence. Replacing the horn (or much of it) with a sub and we waste the design, know-how and built hours put into these big boxes them for a doubtful benefit.
I was just trying to offer an alternative to that, by moderate equalizing.. Anyway Dallas II does offer some very good bass, and they even can be tuned (a bit) lower. I wonder how many here have heard them?
Old 13th April 2017, 01:44 PM   #30
I'd like to put aside for a moment concepts of what is "right" or "pure" or anything like that, and look at something a bit practical.
I'm not fundamentally opposed to frequency equalisation. I'm a vinyl guy, which means that I use a phono stage- A little box that attenuates my treble and boosts my bass. If I already use attenuation on my treble, am I really opposed to attenuating my bass too? Hell, I could just boost it less on the phono stage and end at the same result.
For the sake of simplicity , I'd probably put a splitter on my turntable rca cords. One side to the stereo amp, and the other to the subwoofer.
The important question though is- at what frequency would it make sense to start bringing the subwoofer in and attenuating the speakers?
BLH w/ High Xmax Driver??? goody75 Multi-Way 3 18th December 2011 07:48 PM
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
blh driver bigcatdairy Full Range 11 5th November 2008 06:11 PM
midbass driver for BLH e-side Multi-Way 0 18th February 2006 04:41 PM
Which fostex driver for BLH? boonedog Full Range 12 18th March 2005 12:58 AM
Copyright 1999-2017 diyAudio
