Full Range TC9 Line Array CNC Cabinet
Old 8th October 2017, 11:41 AM   #901
fluid is offline fluid  Australia
I could test a single ended input to the UcD but it would require a cable that I don't have. Focusrite is 1/4" jacks and UcD has XLR input. I would need to cannibalise some other cables to get the right connectors. I have run out of test time now and don't see the opportunity for more for quite a long time.
I checked DC offset on the LKS DAC and it is very low at 0.6mV, the balanced output is trimmed to 0 but that doesn't change the single ended output offset at all.
I had a few Jriver crashes after so maybe Jriver and the cheap Amanero clone caused a DC spike that shut down one channel, the other answer is that the power supply for that channel is faulty, and I would prefer that not to be the answer. I put the Focusrite interface back in so I will see if that helps.
Old 10th October 2017, 07:48 AM   #902
I may have found the cause of my amp shutdown issue, not 100% confirmed yet though.
It has happened every time I played Flamingo by Infected Mushroom, which seemed a little too coincidental hmmm....
So I checked the spectrum with Audacity and got this, that level of ULF could be enough to trip the DC protection in the First One 1.4 as it is DC coupled. Time to try a steep High Pass at a low frequency and see if that fixes it.
Full Range TC9 Line Array CNC Cabinet-screen-shot-2017-10-10-3-39-21-pm-png
File Type: png Screen Shot 2017-10-10 at 3.39.21 pm.png (230.1 KB, 442 views)
Old 10th October 2017, 11:09 AM   #903
I tried a Linear Phase 96dB low cut filter at 15Hz Q1 which is basically a brickwall and it wasn't enough. I got 4:30 into the track before the left channel shutdown again....
Looks like I'll have a try a coupling cap and see if that stops it from tripping.
Old 10th October 2017, 11:36 AM   #904
BYRTT is offline BYRTT  Denmark
Good luck troubleshooting, if you need another trigger it could be the track you shared that ended life gkh's Yamaha's.
Mike Dawes - Overload - Solo Guitar - YouTube
YouTube
Old 10th October 2017, 01:24 PM   #905
Here another trigger candidate in CD quality, length is very short and first two seconds create below spectrum.
Old 9th March 2018, 10:10 PM   #906
8ntractor is offline 8ntractor  Canada
Default sonopan
Hi I know this is an older thread but I was just wondering if anyone has ever tried lining a br cabinet with sonopan the density is very high. thanks
Full Range TC9 Line Array CNC CabinetHide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 07:25 AM
Full range line array in a tube carpenter Full Range 44 7th January 2014 02:19 PM
Omni full range line array??? Melo theory Full Range 42 25th November 2012 05:44 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
line array with full range drivers? leadbelly Multi-Way 9 25th January 2003 04:48 PM
