#31 | |
Just as a remark: My flimsy 8" Audiotechnology driver has more than 30% higher Vd (linear), 50 % larger voice-coil diameter and less ringing and coloration at it's upper end, than this Eton. And the price is not that much higher. But I don't doubt that you will succeed with your project either. As far as the crossover-frequency goes: I doubt that they cross over as high as 300 Hz on this one: http://www.newtronics.de/html/produkte/mega.htm# Regards Charles |
#32 |
i have not seen the Eton specs so cant comment on it. i did use teh 7" kevlar eton in the late 80s and it was a nice driver but that was a long time ago.
from what i rememeber i was told that one of the criteria (for choosing a mate for the Manger) was a high Bl/Mms ratio something in the order of 0.3-0.4 T/g. the other criteria was something called "musicality". this is subjective. Also given that Manger proposes the ZeroBox (not having energy stored inside the box) I would expect it to mate better with a a good 8 or 10" in a TL. The 109 is not a TL but the Qts of the 8" is 0.5-0.6. There are other options one could consider.....aperiodic, Short wel damped TL, TQWT, etc.. but the idea is to ensure that the rear wave is fully absorbed or dissapated very fast. As far as we are discussing high Bl/Mms ratios I am wondering when SmCo and NDfeB magnets become the norm. these magnets will allow us to build the magnetic circuit into a "phase plug", free up the area directly behind the cone allowing the cone to breathe better, and improve the Bl; killing multiple birds with one stone
...still looking for the holy grail. |
#33 | |||
KYW also pointed this out in connection with the thread on 15" woofers; the JBL 2226 (121dB: 1% H2, 1% H3) should produce 10ppm H2 and 10ppm H3 at 90dB, which is likely less than what most high-end amplifiers will add. Quote:
As to IMD, I have not seen the specs for the 8" Seas Excel, but I imagine there might be some reason why Sigfried Linkwitz chose to use it as midrange in his Orion. IIRC, ScottRHinson made a post regarding the low IMD of the Excel series. |
#34 | ||
Regards Charles |
#35 | ||
As to colorations, I think you will find that the Seas Excel series is one of the least colored speakers around, provided they've got real hardware driving them, and have a decent crossover (taking into account the notch filter at 3-5kHz)... Quote:
But it is not really relevant, as I was suggesting the Excel, which can't handle nearly that much. However, it can handle more than the Manger, and the use of two drivers will buy headroom anyway. If you're going to buy the MSW, giving the Excel a go, with an active crossover, isn't a very significant expense. Just have a fullrange switch on the active XO, so that you can turn the Excel on/off according to preference. Just tune the enclosure for the MSW so that it is suited to operate by itself. |
#36 |
angel, it seems to me that you like the seas units - and i'm shure that these are very fine and at least on par with all the other "high end" units......BUT, if one wants "cone area" the seas, scan speak and vifa and others just don't fit the bill......!
nothing beats a 15" (besides 2 x 15".... )
#37 |
tbla,
I mentioned the JBL 2226 (15") earlier in this thread, and its sibling 2241 (18") would fit the bill even better. They'd probably perform pretty well, too. My recommendation of the Excel was based on aesthetics and simplicity of construction. The MSW is about 8" in size, and a similarly sized woofer would complement its appearance nicely, and would make cabinet construction simpler in some cases... The Excel just happens to appear to be the best option in that size range. Of course, if baffle size is of no concern.. by all means, go for larger drivers, as long as their characteristics match those of the MSW (at least frequency response for the first few octaves, and acoustic phase at the crossover frequency)... |
#38 |
One reason (atually the MAIN reason) for unsing an MSW is it's temporal behaviour. You wouldn't want to mess that one up with a 15" (ANY 8" will be better in this respect). You'd rather use (a) 15" as (an) additional sub(s). I have two 2226 in stock, and I once started a closed box for an ELF speaker, using one of these. I will try it together with the MSW two way speakers some day.
Despite of what I've said above I will also try the MSWs on an open baffle together with the 2226es just for curiosity. I have already heard the MSWs full-range on an "open baffle" (actually an unfinished box) and the first impression was good. Regards Charles |
| eton 12"hexacone to manger crossover | slr 5000 | Multi-Way | 35 | 11th September 2008 09:37 AM |
| Manger | phase_accurate | Multi-Way | 84 | 19th November 2007 04:20 PM |
| Manger v ESL | rick57 | Planars & Exotics | 15 | 23rd September 2006 09:45 PM |
| Speaker with Eton Er4,Eton 11-581 and T&P C79 ?? | guru | Multi-Way | 2 | 7th May 2004 09:36 PM |
| Manger....... | tbla | Planars & Exotics | 9 | 11th January 2004 08:13 PM |
