Diy stereo emulation from a single enclosure
Hi!
Are there any diy project that can simulate stereo depth from a single enclosure speaker by altering the source signal? Either by using a circuit or computer software?
Here is an example of a existing speaker that does that;
Between the source and the amplifier an active box is connected wich emulates stereo or even 360 degree 5.0 surround. It works surprisingly well.
Here is some info how it works:
https://drive.google.com/file/d/0B2-Z6DkD83PHRlpNc2FxdDJ6VjQ/view?usp=drivesdk
@ewollowe: Wow, thats a great thread, thanks!
Actually I do have 3 lowther c45 in the basement, I guess you could merge 3 BL horns, with a 30 degree angle and end up with a "furniture" that use the same principle as the nagaoka mx1. Would be fun to try, but quite a hefty project to finish.
