Karlson-ized port patent - diyAudio
Old 16th October 2016, 09:32 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default Karlson-ized port patent
for NEXO
https://patentimages.storage.googlea...50222984A1.pdf
I could see that working in something like my old RJ (18") where the inner two ports would have the cut
Old 17th October 2016, 12:28 AM   #2
Send a message via MSN to Snickers-is
I get a kind of feeling that we are reading this patent differently?
Live sounds better than HiFi.
Old 17th October 2016, 01:37 AM   #3
freddi's Avatar
my RJ above has two fairly long shelf vents - one at the top and one at the bottom of its rear chamber, which feed the front "port". The patent's "V" cut port may be mainly appropriate for some regular bass reflex cases (?)
Old 17th October 2016, 04:32 AM   #4
Well, the way I read it is that this is supposed to solve two main things.
First of all, the cut in the port is supposed to reduce the standing waves in the port. This seem to work pretty well, and I believe it works the same way pretty much on your sub as well.
Secondly, if you look at the product drawing, they get a relatively linear output from the ports, but it is out of phase, and slightly delayed. With this placement of the ports, it gives a dispersion control to the speaker from the ports.
The really bad thing with this idea is that if you use it at low frequencies, they will get an extremely high velocity of air at the most narrow point. This will give turbulent noise. Even cutting a standard port at an angle can cause heavy noise compared to cutting the same port straight.
Old 17th October 2016, 08:07 AM   #5
freddi's Avatar
I've V-slotted a small round duct years ago and as expected it "wheezed" - (will have to read the patent) - is there enough info to start some empirical work? - wonder what the effective length of a V-slot shelf might be? is there a standard guesstimate?
I don't play much with reflex but it could be interesting with light cone midbass speaker.
for a small 20Hz tuned sub (cheap 12" speaker) I have a tapped pipe - if driven hard with sine then it would have some
turbulence - it seems ok with music
this is before it got a finish coat - its was built by Triticum Audio
Is It Sensible To Use The Cabinet As Part Of The Port? (Slot Port) ReDress Subwoofers 4 19th October 2015 06:56 AM
Karlson Patent Question EddieT Full Range 20 21st May 2014 07:05 PM
Would this work - Karlson + slot-loaded port DeonC Subwoofers 27 26th September 2005 08:11 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 01:51 PM
Jamo Concentric Port Patent.... mrfeedback Multi-Way 8 4th June 2003 03:08 AM
Copyright 1999-2017 diyAudio
