Cab suggestions for Alpair 12P. - diyAudio
Old 11th October 2016, 01:31 PM   #1
dekiller's Avatar
Default Cab suggestions for Alpair 12P.
I am running a pair of Alpair 10 Mk.2 on Pencils over a 1.5W SET now. As my new appartment is bigger, I think about an upgrade to Alpair 12P for higher efficiency. As I got low-powered SET and SS in hand only, which cab. design will fit my case best? Living-room is L-shaped. Listenling area about 300 sq.ft., and around 500 sq. ft. in total. Chamber & Jazz is my favourite.
Old 11th October 2016, 02:14 PM   #2
zman01 is offline zman01  Bangladesh
deklller,
2 options come to mind - the Super Pensil 12P (which I have listened to), and the Avebury - both designs from Dr. Scott Lindgren aka Scottmoose.
Old 11th October 2016, 02:45 PM   #3
My suggestion would be go for higher efficiency like 95-99 dB plus. Don't know how the 10 mk II's would go in a Jordan style mini line array @ 4 per side. @the risk of getting shot down in flames. Just putting it out there. Sets I don't have much experience with but as glorious as my SE transformer coupled class A motorola sand amp 24 KG & 1.5 watts rms max sounds I sometimes wish for a little more headroom. The only way is higher efficiency or radical amp surgery.
Old 11th October 2016, 03:10 PM   #4
hajj is offline hajj  Lebanon
hajj's Avatar
Keep in mind that the enclosure only affects the lower frequencies.
So if a driver can give 92db/w @ 1m, which for full range drivers is usually measured in free air at high frequencies, there is no way you could increase that number (except through front loading the driver with a horn, in which case you run into other challenges that I won't address in this post)
The only way to increase the sound output in that case is to use a higher output amp or sit closer to your speakers.
In the case of the drivers you are thinking about (88db vs 92db), the 12P driven by the 1.5W SET would play as loud as 10 Mk2 driven by a 3.5W amp.
Scootmoose's Avebury design advised by Zman is a great option if you have enough room for them and enough distance from your listening position to the speakers...
Nick
Old 11th October 2016, 05:25 PM   #5
chrisb is offline chrisb  Canada
my - I've heard the A12P in only two designs so far - one in a version of standmounter by Dave D that has worked very well with a wide range of drivers, and the SuperPensil referenced above. No contest - even in a room probably close to your description, the Pensil squeezed more of the bass extension from the driver by a substantial margin.
Doncha just hate it when the laws of physics get in the way of your plans for "less is more"?
If I read the OP correctly, which low powered SS SET is in the mix?
... so, not as easy at it sounds, this letting go thing
Old 11th October 2016, 07:05 PM   #6
frugal-phile(tm)
planet10's Avatar
Avebury, Pensil, SuperPensil. Our prototype Mar-Ken was not as good as we would have liked so converted them into A10p Mar-Ken which work REALLY well (loaned them out at diyFEST and can’t remember who ). I haven’t done a large Classic Golden Ratio box for the A12p (and A10p & FF165wk too) yet, but should.
If you haven’t already bought the A12, consider the A10p. It is only marginally less efficient (90 vrs 91), but goes lower, higher and is capable of resolved more small detail (better DDR). Besides a touch of efficiency you will lose a bit of dynamic potential.
It also fits into Frugel-Horn XL.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2016, 08:39 PM   #7
dekiller's Avatar
Thank you very much for all replies.
Brian
Old 11th October 2016, 08:55 PM   #8
dekiller's Avatar
Sound pressure is not my main goal for switching. I have 2A3C and 6L6 SET besides my on-duty 1.5W 6BL7 SET. I am looking for more headroom and dynamics.
Old 11th October 2016, 10:34 PM   #9
dekiller's Avatar
SuperPencil sounds like a good choice. There is a DIY FirstWatt designed SS amp rested somewhere.
Old 12th October 2016, 01:42 AM   #10
dekiller's Avatar
Originally Posted by planet10 View Post
Avebury, Pensil, SuperPensil. Our prototype Mar-Ken was not as good as we would have liked so converted them into A10p Mar-Ken which work REALLY well (loaned them out at diyFEST and canít remember who ). I havenít done a large Classic Golden Ratio box for the A12p (and A10p & FF165wk too) yet, but should.
If you havenít already bought the A12, consider the A10p. It is only marginally less efficient (90 vrs 91), but goes lower, higher and is capable of resolved more small detail (better DDR). Besides a touch of efficiency you will lose a bit of dynamic potential.
dave
Dynamic potential is my main concern for upgrade. As it affect the liveliness of music. Bass comes second. Avebury may not fit into my enviroment since it will block the screen easily. Besides, is there any difference on power requirement for Pencil / SuperPencil?
Alpair 12P with woofer Mike in NJ Full Range 40 7th April 2016 10:48 PM
alpair 12p. First listen murphythecat8 Full Range 32 27th December 2015 12:36 AM
Best box for alpair 12p? carl68 Full Range 14 3rd June 2014 08:25 PM
Alpair 12P quicky mikealanlee Full Range 2 24th March 2013 05:13 PM
Alpair 12P arrival! Monte Verdi Full Range 4 24th June 2012 09:17 PM
Copyright ©1999-2017 diyAudio
