Tweeter terminal polarity - diyAudio
Old 17th August 2016, 01:01 PM   #1
sonyzz is offline sonyzz  Lithuania
Default Tweeter terminal polarity
So i have a tweeter which one connector has black dot on it, and other has nothing, so im assuming that connector with black dot on it is positive side, am i right?
Old 17th August 2016, 07:07 PM   #2
GM is online now GM  United States
GM's Avatar
Probably, but you can use a 1.5V battery to determine it, i.e. when the positive [+] causes the diaphragm to move out, it's the positive lead. Since a tweeter has very little linear excursion, just tap its leads enough to see which direction it moves.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th August 2016, 07:26 PM   #3
Ummm, don't think I'd use a battery on most kinds of tweeters.
The essential question is which polarity results in a better freq sweep. While interesting to know how the gizmo is wired, only audio results when used with a crossover and mid-range count and the sweep tested in your room can be hard to anticipate even for your own familiar system. Often in my experience, both polarities have their advantages.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
Old 17th August 2016, 07:43 PM   #4
GM's Avatar
Why? Which ones? I've used them on everything from cheap ribbons to 7/8" exit horn compression drivers for many decades now with no damage I'm aware of, but one can always use a well worn one that's typically dropped to <1V.
GM
Old 18th August 2016, 01:50 AM   #5
chrisb is offline chrisb  Canada
Now, a 9v "transistor radio" battery ( remember those kids?) might be something to worry about, but I can't see a AA or AAA doing any harm.
... so, not as easy at it sounds, this letting go thing
On the tweeter polarity, again !!! robyonekenoby Multi-Way 10 6th February 2015 02:28 PM
Reverse Tweeter Polarity in a 3-way? G Speakers Multi-Way 9 1st August 2014 01:35 AM
Reversed tweeter polarity martinbls Multi-Way 29 25th July 2011 06:46 AM
tweeter polarity help. joaoveludo Multi-Way 8 10th January 2010 05:53 PM
BAMTM Tweeter polarity 318Shawn Multi-Way 3 2nd May 2007 03:30 AM
Copyright 1999-2017 diyAudio
