Port Position in a (folded) MLTL: Line position and/or baffle position?
Old 16th August 2016, 06:25 PM   #1
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
Default Port Position in a (folded) MLTL: Line position and/or baffle position?
I'm attempting to model a tapered MLTL using the leonard audio software. It's my first TL so have been feeling my way through the process.
The schematic looks like this at present
The response in this setup with appropriate damping seems ok however I'm unsure whether I need to change this to account for a folded MLTL.
i.e. is it the position of the port on the line that matters or is the relative placement of the port on the baffle (assuming it exits on the baffle) in relation to the driver itself also important?
Old 16th August 2016, 07:25 PM   #2
GM is offline GM  United States
GM's Avatar
No.
Both due to the vent's upper harmonics comb filtering with the driver's output, though the more damping used, the less issue it becomes, so in the scheme of things one normally just locates the vent at the bottom where it will generate max acoustic efficiency within the limits imposed by both the driver offset and stuffing density.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th August 2016, 06:30 PM   #3
3ll3d00d's Avatar
Originally Posted by GM View Post
No.
GM
thanks for confirming that
Old 18th August 2016, 02:40 AM   #4
Veleric is offline Veleric  United States
Your cabinet design looks good. And it would be interesting to see your LATL outputs (especially system SPL, driver displacement and velocity).
Also, while I'm a big fan of the LATL model, the one part I put very little faith in is the stuffing aspect. Don't spend any effort optimizing the stuffing plan with the model.
Do the modeling with little (or no) stuffing. Then stuff to taste after it is built. For a design like yours, light stuffing of the first 1/3 to 2/3 of the TL should work well.
Eric
Old 18th August 2016, 08:40 PM   #5
3ll3d00d's Avatar
here you go (and also A desktop MLTL design using the SB65wbac25: Feedback?), this is with 1W
Port Position in a (folded) MLTL: Line position and/or baffle position?Hide this!Advertise here!
Port in non-optimal position ? RobWells Subwoofers 9 25th July 2009 10:51 PM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
TL port position cs Multi-Way 2 20th October 2006 01:21 PM
MLTL correction circuit position Lostcause Full Range 7 24th September 2005 01:10 PM
Port position? MisterB Multi-Way 3 20th February 2002 03:42 PM
