120 degree horizontal dispersion - can I have midrange that does it? - diyAudio
Old 31st July 2016, 11:44 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default 120 degree horizontal dispersion - can I have midrange that does it?
just out of curiosity
Dynavox cone tweeter - horizontal dispersion with cardboard Karlson lens - the upper octave is the same 60 degrees off axis as on axis. An impedance equalizer or perhaps appropriate highpass would be needed to chop off the elevated area on the low end
K-lens - basically wedge shaped cavity - some taper towards the top - a 2 inch fullrange might be used in a FAST configuration. I'm probably more interested in a K-midrange with 120 degree horizontal dispersion to mate with this tweeter arrangement - can it be done without active EQ?
I think my L.Cao F6 which extends to ~17KHz level on axis might make a nice K-mid but there ought to be (?) others less pricey. One of my F6 is currently in the Karlsonator6 prototype, whose aperture probably doesn't have a lot of dispersive effect in the high treble.
small fullrange which have evenly rising on-axis character are candidates for such applications.
What cavity aspect and depth do we want relative to the cone diameter and wavelengths of interest to be propagated ?
Lens
Dynavox tweeter
Old 2nd August 2016, 06:27 AM   #2
panson_hk's Avatar
Sounds like this one does.
Tectonic Elements TEBM35C10-4 Miniature BMR® Driver - Techtalk Speaker Building, Audio, Video Discussion Forum
Old 2nd August 2016, 06:44 AM   #3
freddi's Avatar
that is an interesting little driver - I'd like to have sensitivity at least around 95dB L. Cao's F6 is up there before any lens effect,
Ultra wide horizontal dispersion cabinet design? CZ Eddie Full Range 96 23rd October 2014 05:07 AM
Horizontal Midrange Spacing in a 3-Way 69stingray Multi-Way 6 3rd August 2007 02:21 AM
2-way speaker narrow midrange dispersion - does it matter? arjscott Multi-Way 6 2nd May 2006 04:54 PM
Improving horizontal dispersion on MTM FirebirdTN Multi-Way 3 7th March 2006 09:03 PM
Two Ribbon tweeters to improve horizontal dispersion? goldyrathore Multi-Way 15 31st May 2004 09:10 PM
Copyright ©1999-2017 diyAudio
