BLH design for FaitalPRO 3FE25? - diyAudio
Old 20th May 2016, 01:28 AM   #1
unaHm is offline unaHm  United States
Default BLH design for FaitalPRO 3FE25?
Dear all,
I was wondering if anyone here had made use of the FaitalPRO 3FE25 speakers in a back-loaded horn design, or if there was a suitable design out there that could accommodate them.
They're great speakers, but I'm currently not using them, and I'd love to!
Thanks in advance for your help!
Dan
Old 20th May 2016, 02:18 AM   #2
adason is offline adason  United States
adason's Avatar
Why? You are likely to fail to produce any reasonable bass from 3" mid-tweeter in no matter what backloaded.
Why not fast.
Do not take me wrong, i like faitalpro. I am just being realistic.
Old 20th May 2016, 02:39 AM   #3
frugal-phile(tm)
planet10's Avatar
You might be surprised how much bass can be had… not low bass thou. Just enuff to give you that impression.
They should work in the Frugel-Horn Lite. You may have to use more stuffing than is usual under the driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th May 2016, 02:47 AM   #4
adason's Avatar
Can you post an honest fr response?
Old 20th May 2016, 03:10 AM   #5
Why not fast.
Thanks for the input adason! I'd read around this forum, and seen the concerns regarding the speaker's performance below 200Hz, so my guess would be to just cater for that.
Thanks Dave! It sounds like the Frugel-Horn Lite would work well coupled with a sub or two crossed at 160Hz or something like that. I use the Bill Fitzmaurice T18s, and they do quite well up to 300Hz.
My plan is to use them with a television, but it doesn't need to be a dynamic listening experience, so a thinner Bass response might be more appropriate
Does corner-loading the Frugel-Horn Lites assist their response?
Old 20th May 2016, 03:14 AM   #6
frugal-phile(tm)
planet10's Avatar
Yes. That is how they should be used for maximum bass.
Measuring the response of a back-loaded horn in a room is a can of worms because the room dominates. Move the mic a couple inches and you can have something that looks quite different.
The sim with the FF85wk shows an F10<75Hz. How low it goes in a real room is dependent on the room and the placement in it.
dave
Old 20th May 2016, 04:07 AM   #7
xrk971 is offline xrk971  United States
xrk971's Avatar
This FH3 inspired BLH was made before I had a mic but the bass was rich and full. Tc9fd so 3FE25 should be similar.
FH3-inspired Foam Core Mini Build
Jim Shearer built it too and thought it sounded good.
Old 20th May 2016, 07:30 AM   #8
Seeing these sell for 2500$, and getting quite good reviews, makes the question understandable, I'm considering a pair of Tabaqs myself.
Old 20th May 2016, 09:17 AM   #9
hm is offline hm  Europe
hm's Avatar
Thumbs down 3" driver BLH
Hello,
i made a few BLH for 3", i will test the 16 Ohm in a double horn with 2+2 driver.
Flute sat down to 100 Hz
or the double horns Mini-Posaune, Trombone, Kornett for 2+2 16 Ohm.
Flute
MiniPO
trombone
and new the double horn sat down to 100 Hz, driven with only 110 µF
gets a low membran movement and a superb soundstage near a wall 10-20 cm
http://www.hm-moreart.de/136.htm
Mini Posaune mit 2 x scan speak bass down 35 Hz in my 22 qsm room,
sensational IMP, compair it with any other construction!
real measurements look for example the single simulations below the Kornett measurements
Old 20th May 2016, 10:15 AM   #10
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
A Swedish guy called Linnar did make som FLH for a 4" that could play loud, fully horn loaded that is. a BLH need to transit to a direct radiator above the horn range, here is where things fall appart for small drivers. If the transition is in the 100-200 Hz range the main power octaves is handled by a small direct radiator
FaitalPRO 3FE25 + Peerless Passive Radiator 830878 ? CZ Eddie Full Range 1 19th May 2016 01:46 AM
Faital 3FE25/3FE22 mpa Full Range 33 12th March 2016 01:49 AM
FaitalPro 3FE25 drumanart Full Range 2 29th May 2015 03:28 PM
Faitail 3FE25 (4-Ohm) in PVC enclosures cgallery Swap Meet 0 16th March 2015 02:58 PM
Copyright ©1999-2017 diyAudio
