"Wall-integrated" corner loaded line array with Vifa TC9 drivers
Old 2nd May 2016, 10:28 PM   #11
wesayso is online now wesayso  Netherlands
wesayso's Avatar
While that is true, you don't need the DRC/RePhase programs for playback. Just for the task they can provide after you've made your measurements. Meaning it can be done on a PC anywhere and isn't part of the chain. Aren't there Windows emulators? I really have no clue but I'm sure this step isn't your biggest hurdle.
Old 3rd May 2016, 01:05 AM   #12
perceval is offline perceval  Taiwan
perceval's Avatar
I've run DRC with WINE on my Mac. It works fine.
Then, just point JRiver's convolution plugin to the file DRC created.
The Mac version of JRiver was always a little behind, but mostly for video. They do offer good quality video in the latest version.
Another very nice , but music player only, is Audirvana.
Old 3rd May 2016, 01:14 AM   #13
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
Ooo... I was dreading installing parallels or something but WINE sounds perfect! Thanks for the tip!
My Projects
Old 3rd May 2016, 02:00 AM   #14
ra7 is offline ra7  United States
Hello! So, this is the thread. Looking forward to how this unfolds. I am with Wesayso on the FIR part. It is a no-brainer really. JRiver+PC based EQ and crossover (for HT and subs, maybe?) is the way to go.
One thing I will warn you about JRiver is that it cannot play movies natively like you can on a Blu-ray player. You need some sort of decrypter to unlock the discs. This has been a big problem for me as I don't want to mess with a subscription to decryption software. Once unlocked, JRiver is good about playing the thing and showing you options, etc. And for audio only playback, there is no competition for JRiver, IMHO.
Another thing to be wary of is delay introduced by convolution. If you are playing within JRiver, then the audio and video will be automatically synced, but if you are playing Netflix from a browser, there may be lip sync issues if your convolution file introduces a delay. They used to have a Netflix plugin within JRiver, but Netflix has since denied them this facility. Audio/Video sync will be a problem even with a dedicated FIR box, for example, the one from MiniDSP. JRiver is ahead of the rest in that it automatically syncs video if you are playing inside JRiver.
All this sounds complicated, and it is. There are solutions, but you have to be able to invest the time. I am just about comfortable with JRiver's audio setup, but I have not figured out a comfortable solution for the movie part yet.
Old 3rd May 2016, 02:04 AM   #15
I should ask, Wesayso, what do you do for playing movies through JRiver? AnyDVD?
Old 3rd May 2016, 02:31 AM   #16
perceval's Avatar
Yep, it works fine, but there is occasional glitches, like it tries to redraw the window sometimes. Nothing major and all functions of DRC work as they should.
REW has a Mac version as well, so no problem there either.
I use XLD to convert my files from .wav in REW to .pcm used by DRC. Works great.
https://sourceforge.net/projects/xld/
Old 3rd May 2016, 04:57 AM   #17
oneplustwo's Avatar
Well, I got WINE installed and it seems to run DRC fine. I'm not sure I quite understand how to run DRC yet so I'm sure I'll be asking for help here. I can't seem to find a DRC for dummies resource anywhere but maybe someone here can point me in the right direction.
So you need to run REW too? Is that just to generate the sweep.pcm and inverse.pcm files? And then you use XLD to convert the .wav files from REW to the .pcm files used by DRC?
This sure is complicated!
My Projects
Old 3rd May 2016, 05:13 AM   #18
perceval's Avatar
There's a DRC for newbie that Gmad and myself put up....let me see where it is...
Here: A convolution based alternative to electrical loudspeaker correction networks
Gmad (post #1) gives a more in depth look at DRC, and my guide (post #9) is more a how=to get the files into DRC.
Old 3rd May 2016, 08:16 AM   #19
wesayso's Avatar
For now I just rip every disk I want to play to hard drive in a mkv container. I cannot play DVD or Blu-ray directly without troubles. There are a lot of tools to store movies in mkv files. Not ideal by any means but it's my preferred solution right now. I do the same for audio but you need space, a lot of space, to store it all. Storing them on HD has been the only real option for me to get any ease of use but I can understand not wanting to go there. I'm always cramped for space as my Son regularly wants to watch his old movies again.
As a result I'm not even close to having all my music files on hard disk.
I guess a big, really big, NAS is in my future.
In Netflix I found the option to sync the sound and video. At first I went back to IIR for that but that's hardly a solution once you've heard what the FIR processing can do. Clicking Alt+Shift plus left mouse button gives you access to AV Sync options. Figure the delay out once though sadly you have to adjust it every time you want to play something new.
Netflix never played natively in JRiver over here.
Old 3rd May 2016, 08:19 PM   #20
oneplustwo's Avatar
Thanks perceval, you've given me a head start for sure! I saw the DRC designer option somewhere along the way... is that a good way to go for a noob given the nature of GUI's?
My Projects
"Wall-integrated" corner loaded line array with Vifa TC9 driversHide this!Advertise here!
Corner Floor-to-Ceiling Line Array Using Vifa TC9 ra7 Multi-Way 286 8th January 2018 02:50 AM
FS: Line Array Drivers (8)6"W & (14)1"T Ultima GTR Swap Meet 3 9th January 2015 11:46 PM
6"W x 8"D x 36"H on-wall in a large room. Line array? CZ Eddie Multi-Way 14 20th February 2014 07:39 AM
WTB: Some 4" to 5.5" Drivers For Line Array Zedguy Swap Meet 2 29th March 2009 08:25 PM
Line Array Corner Horn for any 4" driver johninCR Multi-Way 42 1st December 2004 05:13 PM
