Building a Full-Range BMR (TEBM46C20N-4B) Enclosure
Old 30th April 2016, 03:32 AM   #1
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default Building a Full-Range BMR (TEBM46C20N-4B) Enclosure
I purchased a pair of TEBM46C20N-4B BMR full-range drivers from PE long ago and put them aside. I finally got time to take action putting them in a box. I found sutiable box online. This is a plain box with a port as shown below. The net internal volume is around 1 L.
I measured each driver's free-air and delta mass (1 g) impedance for deriving TS parameters. I used them in EnclosureShop of LEAP simulation software to see how the box alignment for the existing port. TSL model of ES was used. The second graph shows SPL of 1 W and 20 W. No filling in the box was assumed. The alignment as shown is not perfect, but not too bad. The peak disappeared for rated input power. I will check the result against measurement.
Old 30th April 2016, 05:57 AM   #2
panson_hk's Avatar
I used a 60 mm holesaw to open mounting hole. The edge of the hole is chamfered at bit for good air flow. Foam gasket was placed surrounding the chassis to avoid air leak. The box was finished as shown.
Old 3rd October 2016, 12:14 PM   #3
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Hi Panson,
I think you used an interesting driver and your case looks great. Can you please share with us how they sound?
But from now on I will be discrete about it.
Old 4th June 2017, 04:12 PM   #4
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
Hi Panson,
Apparently there's not too much bass in these guys, think it's worth the effort to do a bass reflex or should I just add a woofer?
Old 6th June 2017, 12:49 AM   #5
panson_hk's Avatar
Originally Posted by vacuphile View Post
Hi Panson,
Mid-high is okay. Not happy with lacking of bass making overall sound unbalanced.
Old 6th June 2017, 02:48 AM   #6
panson_hk's Avatar
Originally Posted by borispm View Post
Hi Panson,
I added a passive radiator to the box shown in post #1. The passive was optimized for another project. The tuning is too low for the box.
Image below shows simulated (solid) and measured near-field (dash) SPL.
Old 6th June 2017, 03:00 AM   #7
borispm's Avatar
I'm thinking bout trying either the TEBM46C20-4 or the newer TEBM35C10-4 with a woofer/bass module for a wide dispersion setup. Think I can get away with the anaemic bass by Xing at 200Hz?
Old 6th June 2017, 09:32 PM   #8
panson_hk's Avatar
Yes, good idea.
I am using Tymphany low-profile woofer to take care bass. http://www.diyaudio.com/forums/multi...oofer-bmr.html
Old 7th June 2017, 01:27 AM   #9
borispm's Avatar
Yes, good idea.
Wow mate you're really dedicated! I have thought about the GBS as well but realise it may be an overkill... Thinking about utilising my spare TC9FD, cross at 300-400Hz, bring them down to ~100Hz, either use my miniDSP or add a subwoofer.
Building a Full-Range BMR (TEBM46C20N-4B) EnclosureHide this!Advertise here!
Enclosure construction technique help: horizontal or vertical x-sections. gafhenderson Construction Tips 10 2nd May 2012 12:54 PM
Enclosure construction audi0 Construction Tips 15 9th November 2009 10:18 PM
Linkwitz Orion Construction Kit +assembled ASP+Enclosure + Universal Power Supply FS wagnju Swap Meet 2 29th January 2009 08:35 PM
Enclosure Construction Analysis elambert Multi-Way 5 28th January 2007 05:42 PM
Construction Techniques(putting DIY in a proper enclosure) TomWaits Solid State 38 23rd May 2006 02:20 AM
Copyright ©1999-2017 diyAudio
