TB W8-1772 in Spawn (or similar) horn?
Old 27th April 2016, 01:59 AM   #1
mubeen1983 is offline mubeen1983  Australia
Default TB W8-1772 in Spawn (or similar) horn?
Hi guys,
Tried the search but couldn't find any concrete answer, so asking the question here.
I have a pair of Tang Band W8-1772 drivers and am really interested in building a large BLH type speaker. I have searched for available BLH design for this particular driver but there doesn't seem to be many out there. There is one from TB themselves that's published on their site but I can't find any feedback or experience on that design.
I came across the new Spawn family of horn and was very fascinated with the 'Kirishima' horn here - The Spawn Family of Double Horns
I understand that this has been designed for Fostex FE206En driver and one can't just swap out the Fostex with a TB here. However, I would like to ask the experts here if W8-1772 can be used in this horn with good results?
Also, I did notice that W8-1772 probably wont fit in the original 'Kirishima' design due to having a larger driver depth (~111mm). So my second question would be, if W8-1772 can be used, then can it be mounted with an extra baffle of say around 12mm to compensate for the driver size?
Is there any other similar large double horn design that you would recommend that has been proven to work with W8-1772?
Appreciate the help.
Thanks.
Ignorance is bliss. Knowledge is enemy of faith.
Old 27th April 2016, 08:05 PM   #2
falseawake is offline falseawake
Hi mubeen1983,
in Germany there is a shop with a lot of constructions for TB Speakers. For the W8-1772 i found 3 BL Designs:
I'm not sure if this is the TB Design:
Tang-Band-Horn-W8-1772
A detailed test was made in a german diy magazine (Klang und Ton, 01/2011).
Jericho - a well known BL Horn Design (in Germany) for different full range drivers:
Jericho-Deluxe-1772
Viech - also a well known BL Horn Design (in Germany) especially for low budget drivers, fc 70Hz:
Viech-Upgrade-1772
have fun
Old 27th April 2016, 08:25 PM   #3
chrisb is online now chrisb
Well, the expert to ask about suitability of drivers for any of the "Spawn" designs would be their progenitor, Dr S. Lindgren ( Scottmoose)
kinda burnt out - taking a break
Old 27th April 2016, 09:03 PM   #4
hm is offline hm  Europe
hm's Avatar
Default 1772
hello,
look my HP a lot of horns for the 1772,
SCHALMEI, SAXOPHON, RDH20, or: Horn, Posaune XL, trumpet
http://www.hm-moreart.de
Old 27th April 2016, 11:29 PM   #5
Originally Posted by falseawake View Post
Hi mubeen1983,
Jericho-Deluxe-1772
Viech-Upgrade-1772
have fun
Hi falseawake,
Thanks fir sharing those. I have seen the first one, it turned up in google search when I was searching for BLH designs. I think it is the TB version as I have the plans for TB horn and its exactly same. This looks to be a good design but sadly I couldn't find any impressions or review of this horn. There may be some info somewhere on a German site but I don't know German and it usually doesn't show up in google search. Though I did find a German site that had some measurement of this horn and comparison to a TQWT design using the same W8-1772 driver. By measurements and freq response, TQWT looked better (better bass response). So really not sure about this horn yet.
Second one looks interesting, I will check out the details. Though its a bit too big for my requirements. I would need a slimmer front profile, something like the TB design.
Thanks.
Old 27th April 2016, 11:33 PM   #6
Thanks for the suggestion. Will try asking the man himself
Old 27th April 2016, 11:35 PM   #7
Originally Posted by hm View Post
hello,
Thanks very much for sharing your creations. Looks really nice. I will check out your site
Old 28th April 2016, 05:21 PM   #8
I think Bob Brines has a couple of simple designs for the 1772 - BR and an MLTL Tang Band Drivers
If you're interested in something more elaborate, attached is a relatively simple folded horn design a friend of mine - not forum member- has sketched up for me to cut him parts for. I've not heard them yet, but a couple of his other more elaborate rear loaded horns worked quite well. Drawn for 18mm material for the exterior and first fold panel below the driver, and 12mm for the remaining internal panels.
Old 28th April 2016, 05:42 PM   #9
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Here are a MLTL and a BR in different styles.
Bob
Old 28th April 2016, 11:45 PM   #10
Bob
Thanks Bob. Your MLTL plan is top in my consideration list actually. But before I start the actual build, I wanted to explore BLH options too.
TB W8-1772 in Spawn (or similar) horn?Hide this!Advertise here!
Trade: Tang Band W8-1808 for W8-1772 knarfor Swap Meet 3 5th April 2015 02:04 AM
Tang Band W8-1772/W8-1808 without whizzer Darkheart Multi-Way 0 9th March 2014 01:23 AM
Build Thread K-Slot Rear Loaded Horn for Tangband W8-1772 zobsky Full Range 121 19th September 2013 03:43 PM
Tapped horn for TB W8-670C? lost eden Subwoofers 3 31st March 2013 09:00 PM
Will the Tangband W8-1772 work in a Sachiko double horn zobsky Full Range 63 27th August 2010 09:41 PM
