(2) W18E-001 Cabinet w/Port - diyAudio
Old 13th March 2016, 02:30 PM   #1
Default (2) W18E-001 Cabinet w/Port
Hey everyone - sorry to post something so simple but there is so much information I can't seem to locate an answer...
I need to calculate a cabinet volume and port with the referenced woofers. Seas website has (1) W18E-001 in a 25 liter with a port that is 5cm X 15.5cm or 6cm X 23.2cm...-35Hz at -3db.
I'm open to a 3" port because I plan to make these floor standing but I always assumed the port would be longer but when I calculate it I'm getting something like 3" X 6.6125" (sorry for changing units)...is this correct?
Anyway, can someone who is a little more experienced suggest a volume and port size that will have a low cut-off frequency that the speakers and port can handle.
Thanks for any help!
Old 14th March 2016, 05:21 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Using Hornresp to vet the specs, plot a sim and this box calculator, a 28.45 L net tuned to ~34.4 Hz requires a 13.843" long x 3" i.d. dia. pipe: Subwoofer Box Enclosure Design Calculator - Sealed Ported Bandpass Closed Vented
Using the published Fs, Vas, Qts calcs a larger 33.1 L / 32.9 Hz / 12.82" long x 3" i.d. dia. pipe, so the one to use when there's no measured specs and even then may prove to be too small, though Seas specs tend to be pretty accurate.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th March 2016, 06:24 PM   #3
Thank you sir!
Is It Sensible To Use The Cabinet As Part Of The Port? (Slot Port) ReDress Subwoofers 4 19th October 2015 05:56 AM
Pair Monacor SP-60/4 in a stuffed port aperiodic cabinet? What size cabinet? danielwritesbac Multi-Way 28 3rd April 2013 05:15 AM
WTB: Seas Excel W18e-001 original version bbyerle Swap Meet 0 3rd January 2013 09:29 PM
Seas W26FX-001 port help Cousin Billy Multi-Way 11 1st July 2011 01:04 AM
crossovers for seas w18ex-001&t25-001 tomes Multi-Way 1 23rd April 2010 09:13 AM
Copyright 1999-2017 diyAudio
