Old 24th February 2004, 04:41 AM   #1
Default rft drivers
hello,
does somebody knows something about the RFT brand speakers
i m looking for the specs of their drivers, for example the fullrange
RFT L 3401. Does anybody knows this ?
thanx a lot
bye
Old 24th February 2004, 10:17 AM   #2
nobody ?
Old 24th February 2004, 10:57 AM   #3
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Kuei Yang Wang once played with RFT L 3401. He was not impressed. Try to ask him.
By the way: How is your German? You could get more help in some german loudspeaker forums.
www.dipolplus.de
Old 24th February 2004, 02:17 PM   #4
ich spreche ein bißchen deutsch, hahahaah
could you please give me the url of the forum
thanx a lot rudolf
Old 24th February 2004, 02:53 PM   #5
oh yeah,
does anybody knows how old philips fullrangers go ?
im looking at second hand stores now, its a lot cheaper and maybe i found something which isn t bad
thanx a lot
Old 24th February 2004, 07:35 PM   #6
frugal-phile(tm)
planet10's Avatar
Some of the old RTFs are good -- RFT was a large East German OEM so there was a large spread in terms of quality.
The Philips full-ranges are quite good... the older alnicos particularily so, but the newer ceramic 5s & 6s are no slouches either.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th February 2004, 07:36 PM   #7
frugal-phile(tm)
planet10's Avatar
and an RFT
Old 24th February 2004, 07:40 PM   #8
thanx planet 10, but im going for the philips and the saba greencones, they dont cost much and are rather good.
at least thats what i have read about it
Old 24th February 2004, 08:03 PM   #9
frugal-phile(tm)
planet10's Avatar
you should have a much richer supply of both where you are...
dave
Old 24th February 2004, 09:23 PM   #10
indeed, i didnt knew that there were so good things so cheap,
i have found excellent phillips drivers, a guy sells them, there mucg better then the greencones, (he also sells his 2a3 which powered it) it wont go more then 60 euro for a pair, and the same for 8 inch greencones that are in super condition. SO thats exatly what im gonna buy, even for my borther and friends also if it works out fine for me.
But i want a sub and a supertweeter. Even if it sounds very good without. Because i like very deep bass,
BUT NOW SOME QUESTIONS
1) i want to build an woofer, i dont want cinema, i just want extreme fast, clear, transient bass respons, so i got to go for an sealed box i think. what do you think ? Which drivers i gotto buy: i need specifications, because i buy on ebay, so im depending on what they are offering. 2*8 inch of 1*12 inch ? the problem is, that i wanna make a speaker with on the botom the woofer,
the full range in open baffle and the supertweeter : just like the next picture
2) the next problem is offcourse : will the enclosure of the woofer not disture to much the full range ? (i expect that the full range comes it at 100hz or even more). (so mayb it is better with one 12 inch drive then two 8 because of the hight.
3) does anyone has specs of the greencone 8 inch, or the philips 2028, dont find anything.
4)how much energy is going into the drivers, the fullrange is always very limited qua wattage, (off course its high efficency, but maybe the woofer will not be, so we will see) But just for knowing, i think a lot of the wattage is going into the woofer and less into the tweeter. Is that so ?
5)since im a beginner, im gonna put up a measure system, im gonna buy a monacor electret mircorphone, and starting measuring, what software do you use for this ?
well, every comment is more then welcome
thanx a lot guys
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Copyright ©1999-2013 diyAudio
