Porting for Small Enclosure - diyAudio
Old 14th February 2016, 03:04 PM   #1
Default Porting for Small Enclosure
I'm curious about the effect of using multiple small ports vs 1 port of larger diameter. I'm trying to design a ported enclosure for a small portable speaker and in WinISD, in order to have a single port that will fit inside my box, I can use ~0.5 inch diameter, but the "vent mach" number is calculated as 0.13 which by my understanding is getting close to a value where turbulence might cause some unwanted noise.
I noticed that if I use 3 x 0.25" ports instead, the length is fine for the dimensions of my enclosure and the vent mach drops to 0.06. I've read a little bit here and understand that WinISD beta doesn't always calculate this value correctly for multiple ports or for small diameter ports. Just wondering:
1) Does this seem accurate? Would 3 small diameter ports really have an advantage over one larger port with respect to port air velocity or turbulence? (This is what vent mach refers to isn't it?)
2) Are there any other issues I'd encounter with this type of port design?
Thanks!
Old 14th February 2016, 03:21 PM   #2
thedoc is offline thedoc  United States
thedoc's Avatar
If the 3 smaller ports have the same combined volume of air as one larger port there would not be a noticeable difference.
Old 14th February 2016, 03:28 PM   #3
So winisd is not calculating vent Mach correctly?
Old 14th February 2016, 03:34 PM   #4
Inductor's Avatar
Very small ports (fingerlike) don't behave the same way. You can use a small port with short lengths instead of a larger one and longer but you will use less power from port chuffing limit. Resistence from boundaries makes the ports smaller...
Read: Vent Tuning of Ported Systems by Troels Gravesen
The way small ports "in a net" work is different more like aperiodic().
Old 14th February 2016, 04:34 PM   #5
Thanks for the reference. I'll read it.
Old 15th February 2016, 12:30 AM   #6
Xaborus is offline Xaborus  United States
This actually really made me wonder if you drilled a net of holes into the back of an enclosure, if it would end up working as a port, or just a leaky box.
For example, you need a 1 inch by 6 inch port.. But instead you drill 8 holes 1in diameter into the back of your enclosure that is 3/4in thick (8 x 3/4 = 6 in).
Old 15th February 2016, 02:05 AM   #7
freddi is offline freddi  United States
freddi's Avatar
Baruch/Lang patent - -- the speaker became commercially available for awhile
Patent US2766839 - Loudspeaker system - Google Patents
Old 15th February 2016, 01:19 PM   #8
Ron E is offline Ron E  United States
Ron E's Avatar
There is a continuum between a leak and a port. This 8 hole panel depth port would act like a port with the same total area and a length of 3/4". If you add up the circumference of all those ports, it will be greater than the circumference of a single round port, and thus the viscous losses will be higher in such a port. Losses don't generally do any good unless a port is tuned too high, and all they accomplish is that the port emits less sound...and puts less damping or control on the cone.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 15th February 2016, 02:15 PM   #9
Scottmoose's Avatar
...or you get a more highly damped alignment. Not automatically a bad thing; depends how you categorise 'too high' & the design details. Dave does this with his Fonkens / other-Kens, which are generally considered good examples of the breed.
Small wrote off damped vents; they were in his doctoral thesis as I recall, but he omitted them from his published work. However, a goodly proportion of Onkens and their Ultraflex predecessors need some damping in the vents as they're frequently long enough to run into audible issues with their 1/2 wave harmonic structure. Same applies to some other classic BR designs, since the traditional way to do it was to pitch for maximum efficiency at resonance and then damp out what you didn't need via the old click-test, either by stapling damping over the rear of the driver and / or adding more in the box or vent. YMMV as ever of course.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 15th February 2016, 06:43 PM   #10
freddi's Avatar
there was a time around the mid 1950's where distributed hole and slit vents were popular with a GE 12" article and think even EV made one. It was a time of mix and match driver and enclosure based on luck. Some drivers had high qts. Karlson's 12 inch model went to six spaced 1/8" high slits about 10 inches wide. With large ratios of Sd to Sv and diameter in the range of panel thickness or less, they can introduce high amounts (near 100%) of harmonic distortion if fed with sine wave in the box tuning area. With music produced by traditional instruments having mainly transient info , it doesn't seem much of an audible problem. I tried a 43 3/8" diameter hole distributed vent on a 1/2" panel in a 3.6 cubic foot reflex - small signal tuning was around 40Hz - with only 10 watts input at 40Hz to te Peavey 15, it made a nice breeze 7 feet or so away - - under hard drive port rectification seems to happen, input impedance changes probably losing the lower peak characteristic of a reflex for a bit.
Advice for enclosure volume, driver size and porting? DIY coffee table subwoofer ciper Subwoofers 8 21st May 2012 01:38 AM
Sub in a small enclosure Edmunds Subwoofers 18 30th October 2010 01:44 PM
Porting my sealed Enclosure KettermanJ Car Audio 1 6th November 2007 11:45 PM
Porting a fullrange enclosure? HiggityHank Full Range 20 10th December 2003 07:04 PM
Copyright 1999-2017 diyAudio
