4 inch enclosure recomendation - diyAudio
Old 6th January 2016, 01:34 PM   #1
terrago is offline terrago  Bulgaria
Default 4 inch enclosure recomendation
Hello! I have these speakers:
2pcs HiEnd 4inch Full Range Speaker Defy Lowther Fostex New SE Edition | eBay
I want to build desk speakers. Can you recommend enclosure for these speakers? I'm new to this, so please, excuse my ignorance!
Thanks in advance!
Old 6th January 2016, 02:03 PM   #2
Scottmoose's Avatar
I have a few reservations over the marketing claims but leaving that aside, they should go in FH3 for example, and no doubt X could come up with a Karlsonator variation if you fancied something on those lines. Otherwise, a straightforward BR or compact TL variation would be possible; based on the stated spec. they should be relatively flexible in that sense.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th January 2016, 02:07 PM   #3
xrk971 is online now xrk971  United States
xrk971's Avatar
Ahh the whizzer coned AIR/Airborne/AirXXX never seem to go away...
They look really cool, and I would love to get one to play with if they were super cheap - but they aren't quite cheap. The specs are not impressive and really, I wouldn't do anymore than put them in an OB or a sealed box with a FAST woofer support. A Qts of 0.68 and sensitivity of 86dB is nothing special. A Tang Band bamboo cone with no whizzer and Nd motor will sound better.
The response has a +12dB step at 7kHz which will make for some nice ringing and sibillant voice.
Edit: Scottmoose beat me to it and he was more generous. I suppose it might work in a Karlsonator but that large Vas and high Qts would make a bloated box.
Old 6th January 2016, 03:10 PM   #4
Scottmoose's Avatar
Well, in many ways it's a slightly old-fashioned driver, at least in terms of the baseline EM spec. We've largely moved toward drivers with higher levels of damping and a lower volume compliance these days -primarily a result of people wanting smaller boxes, although I suspect the pendulum is swinging back a little (hope so).
Be that as it may. To be honest, I don't like whizzer cones much at the best of times, and I'm certainly not a fan of them on drivers of < 5in, because they really shouldn't be necessary, and the off-axis advantages a smaller unit can have may be lost through the phase shifts & whizzer blanking off sections of the main cone. The same can be said about [so-called] phase plugs for that matter, although usually to a lesser degree. Mostly it's pandering to fashion. Similar to the magnet -the frame looks fairly generic, so it's not getting much advantage from the smaller neo motor in terms of airflow. Probably a bit, so 'every little helps'.
From the data sheet layout, these look to be out of the Guide Sound factory in Taiwan, so they should be built reasonably, whatever reservations I have over the design itself. As far as the sound quality itself goes -YMMV, as always. Acoustics being what it is, what doesn't look great on a 1m on-axis FR may (may ) work / sound better in practice, depending on the context. As far as this one goes, it certainly has some issues. The old 98c tweak with a bit of damping around the base of the whizzer might take out some of the hash around 7KHz, which is probably a reflection. And shifting a few degrees off axis (not too many, or there might be more issues than it resolves given the configuration) may help balance out the top end somewhat. A lot of whizzer-cone units were developed on that assumption, since it does tend to make for a wider practical horizontal / vertical listening arc, at the price of it being a bit hot on axis. I haven't had much to do with Karlson variations, but I suspect that might be of some benefit, albeit the box would no doubt be larger than some other units in this size bracket. Overall, I'm not convinced it's a bargain, and there are a few other 4in units I'd rather have -but I've seen worse.
Old 6th January 2016, 03:26 PM   #5
perceval's Avatar
I talked to Guide Sound lately.
Pretty much everything is now made from factories in mainland China. Most of the offices were also relocated to China.
I'm a little sad about that, but that's how it works these days....
Old 6th January 2016, 03:29 PM   #6
xrk971's Avatar
Do you have these units Perceval? Was it formerly made in Taiwan?
Old 6th January 2016, 04:13 PM   #7
Scottmoose's Avatar
I'm not Perceval, but as I recall, Guide Sound were started & based in Taiwan for many years. I didn't know they'd been largely relocated. A shame.
Old 6th January 2016, 04:15 PM   #8
xrk971's Avatar
Taiwan makes excellent drivers in general. Lots of my in house Dayton that I really like are stamped Taiwan.
Old 6th January 2016, 04:40 PM   #9
perceval's Avatar
Yes, Guide Sound was a Taiwan based company, but they have since moved production and most of their offices to China. For your info: About
No, I do not have those units. I don't know if they were ever produced in Taiwan before, but unless that model is a few years old, then I would venture it was never produced here.
Unfortunately, Taiwan is losing a lot of factories to China.
Another case is Tang Band. A successful taiwanese company that has moved its production to China. Taiwan is still holding on the the head office... but for how long?
Old 6th January 2016, 04:46 PM   #10
chrisb is offline chrisb  Canada
As a former member of the manufacture's forum who is still active in the business would likely assert - with appropriate QC and design, the provenance of production should almost not matter.
Unfortunately that perfect world is a fairy tale, so YMMV
Having said that, a couple of years ago I made a bespoke pair of enclosures for another forum member for a pair of Airborne "wood" ( i.e. reconstituted veneer) coned units. The drivers were quite nicely built, and sounded great - excellent bass. While not capable of the same insane party levels as some of his larger PA systems, I think mr W might still be playing them at more intimate levels- I'm sure I saw some Barry White in his collection, buried behind the JB.
No, I made that last part up.
Or did I, Cal?
on hiatus
21 Inch Enclosure abcdmku Subwoofers 18 17th April 2015 01:34 PM
Horn/TL enclosure for 2 8 inch woofers Michelp89 Subwoofers 11 11th December 2013 01:52 PM
Driver recomendation for shallow enclosure prezden Full Range 7 11th September 2012 07:33 AM
what type of enclosure to use for 6.5 inch Bolton somakmaitra Multi-Way 7 10th February 2006 05:12 AM
Enclosure recomendation for ono audio_cf Pass Labs 1 14th August 2005 11:38 PM
Copyright 1999-2017 diyAudio
