Trying to match enclosure to speaker, need advice - diyAudio
Old 4th January 2016, 04:43 PM   #1
Default Trying to match enclosure to speaker, need advice
I am hoping someone can tell me if the speakers I plan on buying are a good fit to enable the use of a wooden radio cabinet (12.25" x 7.25" x 5.75" inside dimensions) as a portable wireless speaker..
I am thinking to use this bluetooth stereo amp
http://www.amazon.com/Wireless-Bluet...492P+50W%2B50W
and two of these speakers side by side to fill the existing 7 1/2 inch wide opening in the cabinet (was for the original oval speaker).
https://www.parts-express.com/founte...river--296-721
The inside area of the enclosure is 0.30 cubic feet. Sure is a lot different than the .02 cubic feet sealed, .05 cubic feet vented specs of the speakers. Is that a bad match? Do I need to fill most of the inside space with wood blocks to reduce the square feet of air space?
The specs for the TDA7492P chip say that using the 20 vdc 3 1/2 amp power supply that I already have, and two 8 ohm speakers, the output will be 26 watts per channel at 10% distortion. Specs: http://www.st.com/web/en/resource/te...CD00211320.pdf
These speakers are rated 25 watts RMS. Is that a match for this amp?
Any problems putting these two 3" speakers side by side, touching each other (I realize there will be no real stereo separation, but that way they will fit in the existing 7" wide opening)?
Instead of trying to in some way seal the enclosure, is it ok to use the existing back plate, a pressed particle board backing that allows air in around the sides? Is that what is called a vented enclosure?
Do I need to do something to the circuit to avoid speaker thump on power on or off?
Would a 6 ohm speaker be a good choice as well? Perhaos I could find an alternate speaker option.
First 2 way build for a long time - advice to match a commercial speaker smallangryboy Multi-Way 0 10th March 2014 02:44 PM
Mid speaker enclosure advice -Peerless AnamolyDetected Subwoofers 10 24th January 2014 02:31 PM
need advice match driver 2 way haryojo Multi-Way 4 1st March 2013 03:48 AM
dynaudio tweeter match and enclosure beamnet Multi-Way 35 20th March 2006 10:20 AM
advice on a woofer to match fostex fe 103s kepa1 Full Range 3 13th April 2004 06:36 AM
Copyright 1999-2017 diyAudio
