Old 2nd March 2004, 02:07 AM   #11
You know, it's funny you mention that. I thought the compression chamber was unusually deep, compared to most horns. I thought about stretching the height of the enclosure and putting a false wall in there to do exactly what you suggested.
If I did, would there be any problems moving the driver up to the (vertical) middle of the compression chamber? I see many horns do that, so I would think not.
That would help me on (a) overall cosmetics (b) driver getting closer to my preferred height for seated listening and (c) more room - vs the current design - to allow space to attach a grille frame in the area above the driver.
GnD
I had the right to remain silent. I just didn't have the ability. (Comedian Ron White)
Old 2nd March 2004, 02:30 AM   #12
frugal-phile(tm)
planet10's Avatar
Make the false wall at an angle... should be no problem shifting the driver up a bit.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd March 2004, 06:53 AM   #13
petervv is offline petervv  Netherlands
Guys,
I've tried FE103/FE103Sigma/FE108Sigma in the backloaded horn I posted yesterday in another thread, something about 'cool Fostex horns...'
At the moment I'm using FE103Sigma's in a 200Hz Oris103 fronthorns, these are prototypes from Bert Doppenberg. I'm using sand-damping on the plastic horn. On top is a modified Audax PR120i, below is a JBL K120 in a 50Hz horn.
The result is in no way comparable to a single backloaded 103....
reagards, Peter
Fostex FP203 BL-Horn Roemhild Full Range 16 29th January 2013 10:50 AM
Backloaded Horn for Fostex FE 83 becki200 Full Range 34 4th January 2011 12:37 AM
Back Loaded Horn with FOSTEX, some questions... Guijs Full Range 135 31st October 2009 10:58 PM
Fostex 206E in Big Fun Horn atilsley Full Range 0 8th September 2008 06:23 AM
specs on Fostex horn oquela Multi-Way 0 27th August 2007 11:14 PM
Copyright ©1999-2013 diyAudio
