DIY "H" section/project/toy/time waster. - diyAudio
Old 26th November 2015, 12:15 AM   #1
Jerms is offline Jerms  United Kingdom
Default DIY "H" section/project/toy/time waster.
Assuming two flat panel speakers (5mm foam core) - 52x64 rough hexagonal , 44cm apart...
Would the resulting construction be capable of sounding like this...
https://www.youtube.com/watch?v=S5_svSADYks
Those Ikea bowls at 20cm are about the right size for the cockpit section too....
J.
Old 27th November 2015, 04:24 AM   #2
OK, so 2xIkea Blanda Matt bowls acquired.
(ubiquitous so not gonna link to them).
hex panels (wings/radiators/foils whatever) or whatever shapes cut out of 5mm FCB.
40/43mm 1.5" sink/basin drain waste should suffice as the basis for the struts.
2x25mm exciters incoming from Parts-Express.
https://www.parts-express.com/dayton...4-ohm--295-224
Unsure yet as to 2-3 things...
How exactly to attach the exciters to the struts... I guess with sufficient wadding and glue they can be stuck in the ends of the pipe...
Whether to "frame" the hex panels to support them. I don't know if letting the exciter coil support them is a good idea.
The hex panels are curved/warped, so how to flatten them out again. Hold them down and dilute PVA them?
If all goes to plan I have a spare class D amp and a Chromecast Audio to install in the main body.
Portable 12V Audio - DIY "Birdhouse" PS Boombox project xpheolix Multi-Way 0 21st October 2013 03:34 AM
New programming toy for "C", PICs and AVR's jackinnj Everything Else 10 18th July 2009 04:33 PM
"toy" Chip amp Fast1one Swap Meet 0 6th October 2007 12:01 AM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 04:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
