simple question, I am sure the answer is already here but I could not find:
if I want to use a horizontal slotted shape for the BR port, can I use the surface area an length suggested for the standard circular port or should I make changes?
northernsky
northernsky
I do this often, as the extra R added by a higher resistance slot vent helps the box become more tolerant of dynamic T/S changes.
For the boxes i design, my modeler directly gives rectangular vents but i often get ML-TL designs where i use this (http://www.p10hifi.net/FAL/downloads/ChangingPortSize.pdf) to convery circulat vents to slot vents.
dave
dave
Thank you Dave.
In the pdf you attached for quantifying the diameter D2 of the squared duct should I consider the longest or the shortest side of the duct?
If I have to consider the longest one, as I guess, it means that the squared duct is longer than the equivalent circular one. Am I right?
I would like to make a kind of clone of the attached speakers using the Fostex FF103WK. I heard them at an audio show some years ago before the appearence of the Fostex FFxxxWK line and they sounded really good and "big" despite their size (27cm height). They have a 10cm driver in a 9 liters box.
Renato
Renato
Just use the formula with areas.
If the X-section increases so does the length.
I would like to make a kind of clone of the attached speakers using the Fostex FF103WK… 9 liters box
You mean FF105wk? Max size vented box i'd put them in is 5 litres. Otherwise you sacrifice quality for quantity.
dave
dave
I was thinking for a 6 liters box as suggested Fostex;
9 liters is the box of the attached picture.
Thank you. I already built A6.2 boxes for my nephews with the plans you sent me one year ago. I am curious to compare A6 vs FF103WK.
renato
Again, FF105wk, not FF103wk?
Fostex's factory recommended boxes are often fails. We have burned a couple builds after following their plans and have changed the tuning on the BR.
Treated, the FF105wk is a treat. Stock it has some spikes in the HF that bothers some. Still i prefer the A6.2p (it treated to… by a bit)
Which A6 and which box?
dave
dave
Apologize for the confusion: FF105WK.
Online ISD gives almost the same box and and vent.
Concerning my job with A6.2, I built 2 pairs of MicroMar-ken6 one with A6.2p and one with A6.2m.
Both sound very good; to me it was difficult to find differences between A6.2p and m. Maybe, if building again I would choose A6.2m.
renato
email me and i'll give you the change in the mMar-Ken6.2p needed to fit the FF105wk.
I currently have a set w A6.2p that i intend to use in a portable suitcase system.
dave
dave
Done!
thank you
renato
- Full Range
- Bass reflex port shape
