Pics new CNC'd back loaded horn using 4 inch drivers
Old 2nd January 2016, 03:31 AM   #11
atilsley is offline atilsley  Australia
Sanding complete, and second side panel added. Dampening to rear of chamber.
Driver cut-out to do, plus oil with a Teak proof tint added.
Heavy unit...looking forward to listening to them.
Thinking of using the left over CNC'd wood to make a concrete version of the horn.
Andrew
Old 2nd January 2016, 04:37 AM   #12
jwicaksana is offline jwicaksana  Indonesia
That looks really awesome. And I totally enjoy the music you ran thru this speaker.
Jonathan
Old 4th January 2016, 10:42 AM   #13
Thanks.
Finished sanding tonight....one cab started with dark Bees Wax. The finish is very soft to the touch, smooth.
Driver cut outs tomorrow, then fit cable, terminals, drivers....done.
A nice high end speaker, yet compact. Kits available.
Old 4th January 2016, 02:15 PM   #14
perceval is offline perceval  Taiwan
perceval's Avatar
Great! Looks very nice already!
Bees wax... that's a nice idea. Used to put that on my boots! Probably works well on wood too!
Old 4th January 2016, 02:27 PM   #15
zman01 is offline zman01  Bangladesh
atilsley, looking good!
Old 5th January 2016, 02:53 AM   #16
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Very nice.
Good to see someone rounding the ports off on corners to get better transmission.
I see too many projects with ports with right angled square corners. They used to use right angled corners in trenches during the first world war to stop blasts travelling the full length.
The right angled corner just returns the blast the way it came.
PCBCAD51 pcb design software. 2018 version out now >>>>>> http://www.murtonpikesystems.co.uk
Old 5th January 2016, 04:23 AM   #17
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
In a BLH, you want hard angle turns upstream to serve as low pass filters. You don't want mids or mid bass coming out. The mouth it makes sense to smooth from aesthetics and also to prevent a hard distance anchor for a reflection cancellation.
Old 5th January 2016, 10:12 AM   #18
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Very pretty indeed.
I fear you've somewhat missed the point. A smooth pathway in a back horn promotes maximum efficiency over its entire operating bandwidth, primarily affecting the shorter frequencies at the top end of that range. However, there are equally valid alternatives, one of which is to design the horn to include and use sharp bends, edges and CSA shifts at specific points in the expansion path as a functional part of the low-pass filter. So if you see them in a back horn, it does not necessarily mean it is a poor design. It might actually be the reverse.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th January 2016, 03:59 AM   #19
SufferingArtist is offline SufferingArtist  Singapore
Banned
Originally Posted by atilsley View Post
Thanks.
Point us to the kits, pronto!
btw, what's the -3db like for the bass if placed about a foot from a back wall?
thanks!
Old 6th January 2016, 04:14 AM   #20
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Andrew,
That is not really a horn, but an unstuffed end-loaded TL. I suspect it will have significant ripple in the response.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Pics new CNC'd back loaded horn using 4 inch driversHide this!Advertise here!
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 09:32 PM
Is this a back-loaded horn? zcables Multi-Way 3 17th September 2012 05:48 PM
Combination of Back-loaded Horn and Fron loaded horn?! ARIYAHOOR Full Range 26 1st June 2012 10:20 PM
Back Loaded Type Horns using Fostex 4 inch FE 103E Single Drivers. davidhugo Full Range 12 18th December 2009 08:27 PM
Pics of CNC routered Big Fun Horn atilsley Full Range 6 22nd October 2008 09:53 PM
