What is better than JXR6 HD - Current state of the art drivers for FAST
Old 9th April 2018, 05:05 AM   #91
MITsound is offline MITsound  Canada
MITsound's Avatar
Originally Posted by deandob View Post
Tigerdog, did you manage to contact EAD for your Sweden trip? I have tried emailing them and registering as interested in their MKII drivers but have not heard back. They have obviously had some delays although the last news was that the drivers were almost ready for production back in September.
My JXR6HD drivers are getting worse as the spiderless design makes it easier for the voicecoil to rub/rasp and I get temporary relief by flexing the cone however this obviously isn't ideal. Time to replace.
I'm open to any other suggestions for drivers that are as good or better than the Jordan JXR6HD but am wary of trying another driver set and it not meeting expectations (especially in the higher frequencies which are very nuanced with the JXR6HD).
Colin, given your background with EJJordan and now that the JXR6HD is out of production, do you have any recommendations for replacement?
I just rediscovered my old pair. Loving them just sitting atop dual 15 inch Onkens, actively crossovered 4th ordered at 800 hertz.
Do you think I'll have voice coil issues?
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 9th April 2018, 11:29 AM   #92
Colin is offline Colin  United Kingdom
The JXR6HD and short-lived JX62 were the last of the smaller drivers produced by Jordan (both manufactured by MarkAudio). Ted then moved on to an all-out assault on refining and improving the 100mm cone driver, resulting in the Eikona 1 and then, with a few more refinements, the Eikona 2. Although it doesn't have the HF reach of JXR6, we all preferred the Eikona and ceased development of the 50mm design. We have customers who are using it in the FAST concept, with a powered bass system.
Although ostensibly based on Ted's 1990s designs, the EAD models went their own way and were not approved by him.
Incidentally, the JXR6 problems can sometimes be sorted by rotating the driver on the baffle through 180 degrees and remounting. The problem is that the ferrofluid makes a good damping element, over time it allows the cone to drift off-centre.
EJ Jordan Designs
www.ejjordan.co.uk
Old 9th April 2018, 11:39 PM   #93
MITsound's Avatar
Thanks. Maybe I'll put them on a rotation schedule, at the start of each month. I like them better by far than some 4" whizzer coned eBay paper drivers, and actually prefer them over my 12P and 12PW pairs.
Surprising to me, because I've preferred paper drivers for years. Sadly, I'm down to my last 3 pair of ancient NOS Peerless 16 ohm 2" alnico tweeters. Nobody makes 'em like those, anymore!
Old 12th April 2018, 05:07 PM   #94
MITsound's Avatar
Since I'll be experimenting with some Class A 10 watt solid state amps, I wanted some more efficient drivers. A pair of Faital Pro 3Fe22 8 ohm Neodymium drivers is on the way. Hopeful they'll be an even better match to my dual 15" Celestions in their Onken boxes.
They are paper drivers, like the 15"ers, look to have a quite good off axis response, easy to mount, and are fairly inexpensive.
I've yet to be let down by pro drivers, but am curious prior to delivery. Has anyone tried these as dipole, minimal baffle?
Old 13th April 2018, 06:52 AM   #95
Russell Dawkins is offline Russell Dawkins  Canada
I'm curiousódid you consider the 4Fe32 8Ω version? If so, why did you go with the 3" driver?
Old 13th April 2018, 02:46 PM   #96
tigerdog is offline tigerdog
I did not speak with them. I did walk by their listed street address and found nothing but an apartment building with shops (not audio shops) on the ground floor. Leads me to believe they are a very small outfit indeed.
Old 13th April 2018, 05:52 PM   #97
MITsound's Avatar
I already have some 4" full range drivers, and hope a 3" will have better off axis dispersion.
I may have wasted my money on the pair anyways. I was ready to dust off and sell my Bohlender Neo 3, 8, and 10 pairs, but the 10s are wonderful just sitting atop in their Meniscus Audio flushmount frames.
I only notice the missing top octave if I'm pretty much directly in a tweeter's line of fire.
10,000 hz and up must be pretty beamy; I wonder how much of it we hear when not "locked in" to a critical listening window.
The Faitals will need to be very very good for me to part company with the dipole Neo 10s sound, from 800hz and up.
What is better than JXR6 HD - Current state of the art drivers for FASTHide this!Advertise here!
STATE OF THE ART Dr.H Digital Source 0 23rd April 2013 08:53 AM
State of the Art TODAY Krisfr Solid State 10 11th October 2009 01:43 AM
What's the current state of the art chip amp? Bricolo Chip Amps 5 27th April 2005 11:44 PM
state of the art relays Berki Parts 63 29th October 2004 02:33 AM
LM3875 Gainclone-current state of the art survey Dr.H Chip Amps 5 13th August 2003 07:18 AM
