Audio Nirvana Classic 12 and Classic 15: how new are these?
Old 27th October 2015, 01:49 AM   #11
freddi is offline freddi  United States
freddi's Avatar
when I last checked my old stamped frame AN Super8's (just sitting), fs had climbed about a half octave - don't know if permanent or will drop again with use. That's in interesting approach to contain the angles with a built-in "horn".
Old 27th October 2015, 02:40 AM   #12
Mr Daniel is offline Mr Daniel  United States
[QUOTE=norman bates;4496561](without listening) I'd say so long as you don't mind losing a bit of dispersion, the "classic" should sound better (less ringing whizzer anyway). But I also know a whizzer (done right) can be made to bring down the climbing response of a cone driver.
I think someone here liked the classic 10 over the whizzered 10".
I think the super 8" cast frame has a climbing response that would require an equalizer, but listening off axis should smooth it right out.[/QUOTE
Question? Which speaker company has done the whizzer cone right on a full range driver? Where it brings down the climbing response of the cone driver? Mr. Jeff
Old 27th October 2015, 06:30 AM   #13
norman bates is online now norman bates  United States
norman bates's Avatar
Coral
whizzer and intelligibility ?
Old 27th October 2015, 04:50 PM   #14
GM is offline GM  United States
GM's Avatar
Originally Posted by Mr Daniel View Post
Thanks for the info. Maybe my old computer was not protected?
You're welcome! Dunno, I mean I don't recall Symantec, Avast! [don't remember which I had back then], Malwarebytes giving me any warnings, etc..
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th October 2015, 05:00 PM   #15
GM's Avatar
IME, best to tweak your own to 'taste':
Chinese/Taiwan 4 Dual Cone Speakers
GM
Old 1st November 2015, 11:15 PM   #16
Bigun is offline Bigun  Canada
Bigun's Avatar
Bud Purvine looked carefully at the AN15 and he liked the whizzer - said it was one of the best implementations he's ever seen. He compared the AN15 to an electrostatic - clearly he's a fan of this driver. I have one in an open backed box and find it performs well. Treble is not perfect of course, but boy there is very little compromise here given the wall of sound this driver produces when asked. And I'm driving it tonight with a 650mW Single Ended triode-wired pentode Spud amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 2nd November 2015, 07:02 AM   #17
Bigun, still 1 open backed speaker ?
I finally found what I'd meant about covering the backside of an open baffle with foam.
Old 2nd November 2015, 04:06 PM   #18
GM's Avatar
Right, this to me is how 'full-range' OBs should be damped when the baffle + room boundary isn't large enough to contain its BW to low enough for the rear wave to only damp the driver's Fs and/or when BW limited to the ~ mids in a multi-way.
GM
Old 3rd November 2015, 01:13 PM   #19
hajj is offline hajj  Lebanon
hajj's Avatar
One must be very careful with Audio Nirvana's published T/S parameters.
I have owned both the super 12 and super 8 stamped frame drivers, and besides the fact that they sounded dreadful (tried several enclosures and amps, including a high end SE EL34), the T/S parameters were all over the place.
David is very good at marketing his products but the quality and consistency at the time (some 4 years ago) was really lacking...
Never tried the horn ones though.
Let us know how they sound if you pull the trigger.
Nick
Old 3rd November 2015, 04:53 PM   #20
I find that full range drivers need eq, always.
Audio Nirvana Classic 12 and Classic 15: how new are these?Hide this!Advertise here!
Box design for Dayton Audio DCS385-4 15" Classic Sub Ninesvnsicks Subwoofers 98 26th November 2015 10:29 AM
Audio Nirvana Classic eventhorizon Full Range 44 3rd January 2015 10:14 PM
who owns audio nirvana classic ? norman bates Full Range 4 22nd July 2014 10:30 AM
New 2-Way Build - The Classic 15 Loren42 Multi-Way 59 24th July 2011 07:16 PM
FS: 15-inch Dayton Classic IIs jmikes Swap Meet 0 12th March 2007 01:16 PM
