Full range first build suggestions
Old 12th September 2015, 08:34 AM   #1
monkeychops is offline monkeychops  Canada
Default Full range first build suggestions
Hi there, extreme lurker here.
I'm looking for some suggestions for a first time speaker build.
I'd like to build a really nice looking pair of speakers with terrific dynamics and bass extension. Something similar in sound to the older Klipsch or Cerwin Vegas but hopefully with a somewhat smaller footprint.
If its super efficient and can run off a little tube amp then that's a bonus.
I have fairly advanced woodworking skills so any cabinet design should be possible. I'd like to keep the parts under $500.
Old 12th September 2015, 09:38 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Hi, this surely belongs to multi way forum
as you fail in the typical miscomprehension that "fullrange" is to be attributed to the perceived sound rather than to the ( single) driver that has to make it.
Old 12th September 2015, 05:34 PM   #3
chrisb is offline chrisb
I'm still a big fan of "FR" ( read single driver for most of the audio band) systems, but would have to agree with pico at least to the extent that you might want to research Hoffman's Iron Law - this is a good an explanation by a well respected loudspeaker manufacturer as I think you'll easily find:
Sensitivity and Hofman’s Iron Law, or “why you can’t have your cake and eat it too” ? Audioblog
short summary - pick any two of the following:
- deep bass
- high sensitivity
- small size (can refer to either driver or enclosure)
How large is the room this system would be playing in, and is the enclosure size constraint due to WAF? If so, then she should be consulted in the choice of design & finish
That said, you could do worse than Mark Audio Alpair 10.3 in a BLH such as the FHXL - all well within budget for an accomplished woodworker.
kinda burnt out - taking a break
Old 13th September 2015, 04:42 PM   #4
GM is offline GM  United States
GM's Avatar
Originally Posted by picowallspeaker View Post
Hi, this surely belongs to multi way forum.......
Normally true, though with the exception of a smaller footprint unless built to fit into a corner to complete its expansion, a large front and back loaded [compound] horn for a high end Lowther or similar driver will theoretically meet his performance requirements as well as offer a bit of a challenge for his woodworking skills; otherwise, with 'only' a $500 budget for parts, especially if BB ply or similar wood is part of it, he will have to sacrifice both efficiency and the 'full-range' clarity of a Klipsch, CV.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th September 2015, 05:48 PM   #5
xrk971 is offline xrk971  United States
xrk971's Avatar
This will challenge your wood working skills. 108dB sensitive and drivers don't cost a lot. Sounds great. Use the 3FE22 for the main full range driver and upgrade the 6.5in woofers to something with higher sensitivity and still stay in your $500 price cap.
http://www.diyaudio.com/forums/full-...x-synergy.html
Old 13th September 2015, 06:19 PM   #6
Hmmm how can a speaker system get some sensitivity boost when the midrange is rated below or 90 dB/W/m ( 2.83 V for sensitivity err.... )
The woofer itself, if of "higher efficiency" collides with the
Originally Posted by monkeychops View Post
bass extension.
as you'd need to reduce mass or...
The notion of "don't cost a lot" and "sounds great" is arbitrary
And wood, for making LS's is
only if
Old 13th September 2015, 09:27 PM   #7
xrk971's Avatar
The horn loaded 3FE22 is 108dB. The mids or woofers are just 88dB in series parallel for 94dB at 2.83v. That is why I said to upgrade woofers or mids.
Old 14th September 2015, 12:05 AM   #8
gearhound is offline gearhound  United States
My old E-V 8SPC 8" full range drivers are rated at 95db eff.
They are in 1.1cf rear ported home brew cabinets
Bottom end rolls off quickly below 55hz.
Top end nose dives above 12Khz.
I use a 1" soft dome Vifa tweeter (94db eff), crossed over at 10Khz/first order, to extend treble out to 20Khz.
Unless you plan on using a 3/4 watt Darling tube amplifier, I've found that I can get loud volume, with as little as 2.5 watts from a pair of 6bq4/6aq5 SEP tube mono blocks with mid-90s db eff. drivers.
Steve
Old 14th September 2015, 04:22 AM   #9
talaerts is offline talaerts  Belgium
This speaker kit should be inline with what the OP required, except it will be at approx $150 more than $500 for a pair. Otherwise I expect it to give a modern approach of that big sound in a reasonable footprint that he is looking for:
Fusion-12 Tempest DIY Sound Group
Full range first build suggestionsHide this!Advertise here!
Any Suggestions between these two full range? liuz3 Full Range 60 13th July 2015 07:35 PM
Dayton PS-220 8" Full Range Build Suggestions ani101 Full Range 11 10th July 2014 10:17 PM
Contemplating First Full Range Build. Suggestions? Xaborus Full Range 44 4th October 2013 08:12 PM
Full range project - Suggestions cyberlancer Full Range 10 18th September 2012 03:06 PM
Cheap small full range suggestions ? Bare Full Range 52 4th August 2012 06:37 PM
