Carfrae Little Big Horn "Lite" - diyAudio
Old 13th August 2015, 10:34 AM   #1
Default Carfrae Little Big Horn "Lite"
I've built this using CAD CNC...and is a slightly scaled down version on the full model with powered sub.
I like the look of the curved sides.
Suitable for Fostex, Tang Band and Lowther....this one was using DX3.
This could be machined in MDF or ply...depending on what finish is desired.
See also pic of white full version which a gent in NZ built using my CAD CNC kit.
Andrew
Old 13th August 2015, 11:11 AM   #2
xrk971 is online now xrk971  United States
xrk971's Avatar
The design looks very beautiful and organic. It must have some very nice bass. I do have a question why such a round baffle around the driver bezel is used. I have done this once and found first hand that the warnings of the round baffle being the worst of all is true. There are huge 6dB to 10dB dips due to round baffle diffraction effects that simply go away when using a rectangular or trapezoidal baffle. It's true as the measurement positively show it and it sounds not so pleasant. Just a warning for folks out there who may be wondering why the response of an otherwise flat response driver is ruined - the round baffle is the cause. For this particular case, it may not be as bad as a round disc baffle as there is sort of a rectangular horn wall housing behind the round baffle protrusion - but there may be some residual diffraction effects at the higher frequencies that would be improved simply by making those round discs rectangles.
More details on the theory by SL here:
Diffraction from baffle edges
Old 13th August 2015, 11:49 AM   #3
Thanks...the original design is Jim Carfrae's, so I'm not sure what assessment he made in this regard. Certainly, the supporting plate behind the ring, plus the main body will reduce diffraction, as you say.
Having built many horns, I can attest to the enjoyable presentation of the Carfrae, particularly the bass, as the large tractrix curve works very well.
(See attached pics of my own designed C-Horn for Lowther.
Kind regards. Andrew
Old 13th August 2015, 01:01 PM   #4
xrk971's Avatar
Thanks. Your see thru plexiglas wall horn is perhaps the most beautiful of all BLH's I have ever seen. Nice work there!
Old 13th August 2015, 01:24 PM   #5
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
I've often thought that the big open unused circular space behind the driver in the Carfrae would be the perfect place to add a dipole/OB woofer from AE or something..
Old 13th August 2015, 11:00 PM   #6
Thanks. a few more pics.
It's 'easy' to build.
I've enjoyed testing all sorts of drivers...DX3, 206E, B200 Visaton etc. I'd like to try Tang Band next.
Old 13th August 2015, 11:04 PM   #7
Like this what someone has tried?
Old 14th August 2015, 11:30 AM   #8
Soakin' up the Sound!
mikejennens's Avatar
Are any plans/drawings available for this? The cisrcular cuts might be a challenge without the use of a CNC, but once one was done correctly, it could be used as a template for the rest. In that lind of thinking, a guy could have on done by a shop with a CNC and use it as a template.
Thanks,
Mike
Marantz PM8003 amp, Jolida SJ502A, Squeezebox Touch, MLTL Continuums; MarkAudio A 7.3 Frugalhorns, MarkAudio CHP-70s
Old 14th August 2015, 12:38 PM   #9
Thanks,
Mike
Hi Mke, yes, I have files for CAD/CNC...but would need to take that offline. Kind regards. Andrew
Old 14th August 2015, 12:43 PM   #10
Thanks Andrew. I should have more clear with my question. If I wanted to try this without the benefit of CAD or a CNC, are there plans available to do the cuts by hand?
Mike
Frugel-Horn Lite for 3" drivers planet10 Planet 10 hifi 27 27th July 2015 09:27 AM
Pics Carfrae Little Big Horn "Lite" - kit atilsley Full Range 5 13th February 2015 07:28 PM
Simple, Big 18" Horn for Club use elleman Subwoofers 10 28th February 2013 09:39 PM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
New Semisouth SiC "JFET Lite" wrenchone Pass Labs 14 21st April 2012 11:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
