Monacor SP-155X too good to be true? - diyAudio
Old 20th July 2015, 11:14 PM   #1
monty78pig's Avatar
Send a message via Skype™ to monty78pig
Default Monacor SP-155X too good to be true?
I've been mucking around with BRs in WINisd recentley, and having previously built a stereo closed cabinet for Monacor's SP-155X, as an external speaker for a television to sit on top of (not too critical an application, hence the choice of a rather cheap driver), I decided to see if it could be used in a BR enclosure.
Plugging the values into WINisd and changing the box volume to 50l, tuning at 48Hz it looks pretty good, with an f3 of about 40Hz, although a little bumpy towards the end but I'm guessing that'll help compensate for baffle step error. It also seems to have some degree of this built into it's response making a baffle width of about 25-28cm ideal, which also fits into the golden ratio dimensions using 18mm MDF.
The sensitivity is also decent, about 93dB making it good for use with an SE pentode amp. However, Qts is high (which means bass will be less controlled? ) and the Xmax is limited to about 1mm.
It is a very cheap FR, about 40 for a pair, coupled with some MDF cabinets with some faux grain painting (something I'm very proud of being able to do ) could make for a cheap pair of speakers.
I'm sure there's a catch to all of this though, go on, tell me how I'm wrong !
78RPM Restorations https://soundcloud.com/monty78pig With perfect linearity, it is impossible to go off on a tangent.
Old 21st July 2015, 06:23 AM   #2
jerryo is offline jerryo  Isle of Man
Nice to hear about someone doing graining. I did a bit myself a good few years ago. It can be very effective when done well. I recently came across a monumental amount of graining in a large Victiorian House undergoing a complete refurbishment a couple of years back whilst doing some set decorating on a film. All internal doors and frames including a huge set of double folding partition doors dividing a large reception room into two were figure grained in Oak, and done to a very, very high standard. Really impressive work of a master craftsman. A joy to behold.
Old 21st July 2015, 11:58 AM   #3
monty78pig's Avatar
I find it quite fun, I think it looks amazing on MDF! I think it's not just about using the rubber tool but also using a coarse brush up and down along the faux grain while it's half dry to really get a good close up effect.
I'm not amazing at it, my first few attempts looked rather contrived as I was using the rubber tool in the same position on each stroke.
Old 21st July 2015, 12:14 PM   #4
I have good books on the subject if you ever wish to borrow one for improving technique.
Back to the Monacors: there are some drivers by Monacor named SPX200 wp which I am keen to find out about although they are hard to get hold of. I'm waiting to hear when they are in stock. They model really well on WinIsd Pro.
Old 21st July 2015, 12:21 PM   #5
Did it Himself
richie00boy's Avatar
Very high Qts and a box much larger than VAS is going to result in a muddy sound. Check the group delay curve.
It's worth a build though as a listening and learning exercise.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 21st July 2015, 12:45 PM   #6
monty78pig's Avatar
Hmm... The group delay is a little high, peaking at 23ms at 40Hz. Objectively speaking, will I hear this?
Here's the group delay graph, the lower trace is for a pair of MA A10P BRs I'm also rebuilding at the moment for comparison
I'd love to borrow your book but the Isle of Man is a long way away !
Old 21st July 2015, 01:42 PM   #7
Squeak is offline Squeak  Denmark
Squeak's Avatar
The catch? It's not that inexpensive. I just think you were lucky. The price is between 40 to 50 pounds where I checked.
At that price I'd much rather get a similar Fostex with lower Qts and better materials overall, at a small extra price increase if any.
Old 21st July 2015, 11:26 PM   #8
monty78pig's Avatar
Hmm... I can get a pair of these drivers for 40 which is not bad at all. Factoring the cost of the MDF and grill it comes to just under 100.
They will be pretty big though 28x36x68cm!
Old 22nd July 2015, 12:11 AM   #9
Squeak's Avatar
The extra dough for a pair of FE166 is well spent considering you could be living with them for a long time.
If not the resale value for Fostex is higher.
Alternatively FE126 is about the same, with likely a little less bottom, but more precision there and better dispersion and no wiz cone.
I'd say you get about what you pay for here.
If they had been something south of 30 it would start to look interesting.
Old 22nd July 2015, 12:14 AM   #10
monty78pig's Avatar
FE166 don't perform well in BR, besides they would cost 140 just for the drivers .
Monacor SP-80x jayce996 Full Range 0 17th April 2013 09:55 AM
Monacor SP-80X, any experience? Indigestible Full Range 0 31st July 2009 03:05 PM
Monacor SP 60/8 needed Cambe Swap Meet 1 1st August 2002 12:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
